View Poll Results: which lsa?
112
20
37.74%
110
33
62.26%
Voters: 53. You may not vote on this poll
112 vs 110 lsa
They dont make them in a self aligning version in the 1.7 ratio, so you'd have to use guide plates. Thats an easy swap though, so I don't know why that would keep you from using them.
http://www.flatlanderracing.com/scor...chevySelfAlign
Well the reason I was asking was to see if they were available to put on an iron headed impala motor while the heads are on.
well if you had no problems with the 224/230 im probably still gonna go that route. If I could afford the best of everything i would go with more lift, but i think the 224/230 has a pretty decent ammount as is. Just one more question for ya... are you running an XD timing set and do you think its necessary? like i said i know someone who isnt, but i dont wanna bust the thing.
Actually guys the lift has a lot to with power output but it does depend on how you do it and some cams with lower lifter are harder on parts than cams of the same duration with more lift. It's a very complex amount of physics going on in there and things that seem intuitive like more lift is harder on all the parts isin't always correct.
Bret
Bret
Bret
Bret
Actually in a lot of instances it goes thru the whole line and not always the same lobes in the same familys fit the rules or the applications.
BTW there is not even a 314X lobe in there.... but I get what your saying. I don't comment on particular lobes but the measurement of the lobes is not easy to do simply enough where I can just give you the HOW to do it.
You gotta look at all the lobe specs and what they are relative to each other, that's the key. If one thing is way off say lift or duration at a certain spec it can throw EVERYTHING out of wack.
Bret
Bret
Not to hijack the thread any more, but since you're talking about mods on Impala heads I figured that I'd let ya know that I have a pair of bare unmolested Impy heads sitting in my garage that I'd like to get rid of if your interested....if so, PM me
