View Poll Results: which lsa?
112
20
37.74%
110
33
62.26%
Voters: 53. You may not vote on this poll
112 vs 110 lsa
Old Dec 6, 2006 | 05:31 PM
  #61
Colin91Z's Avatar
Originally Posted by SStrokerAce
BTDT as I said before a lot of BS to do it.
Bret
I wouldn't run them, I'm just tryin to help the guy find what he's looking for
I'll be running the 1.52 pro mags as per your instructions
Old Dec 6, 2006 | 05:36 PM
  #62
chrism400's Avatar
Originally Posted by Colin91Z
They dont make them in a self aligning version in the 1.7 ratio, so you'd have to use guide plates. Thats an easy swap though, so I don't know why that would keep you from using them.
http://www.flatlanderracing.com/scor...chevySelfAlign
Well the reason I was asking was to see if they were available to put on an iron headed impala motor while the heads are on.
Old Dec 6, 2006 | 05:41 PM
  #63
Colin91Z's Avatar
Oh I see, well in that case it's not such an easy swap
Old Dec 6, 2006 | 06:02 PM
  #64
chrism400's Avatar
Yea, to put guideplates on the iron heads, the studs have to be pulled out, the bosses machined flat and then tapped. Kinda tough to do on the car.
Old Dec 6, 2006 | 06:05 PM
  #65
turbo_Z's Avatar
Originally Posted by foggedz
Why wouldnt you do it again. What kind of problems have you had?
No problems... Id just like to see more lift. Thats my basis on suggesting the other 2 cams over mine.
Old Dec 6, 2006 | 06:06 PM
  #66
chrism400's Avatar
Sorry for the thread hijack.
Old Dec 6, 2006 | 06:26 PM
  #67
JoeliusZ28's Avatar
well if you had no problems with the 224/230 im probably still gonna go that route. If I could afford the best of everything i would go with more lift, but i think the 224/230 has a pretty decent ammount as is. Just one more question for ya... are you running an XD timing set and do you think its necessary? like i said i know someone who isnt, but i dont wanna bust the thing.
Old Dec 6, 2006 | 06:36 PM
  #68
chrism400's Avatar
Just get an LT1 replacement chain. I think I got mine from AutoZone for like 100.00 bucks. It's made by Cloyes, and has about 4000 miles on it. If you want it, pm me for a deal.
Old Dec 6, 2006 | 10:05 PM
  #69
Z95m6's Avatar
Well lets put it this way he's running a cloyes double roller. We both can't afford the money or the time to have to rebuild our motors because we want to save a few $100 on a timing chain. If you really go with ported heads the lift could pay off.
Old Dec 6, 2006 | 11:54 PM
  #70
SStrokerAce's Avatar
Actually guys the lift has a lot to with power output but it does depend on how you do it and some cams with lower lifter are harder on parts than cams of the same duration with more lift. It's a very complex amount of physics going on in there and things that seem intuitive like more lift is harder on all the parts isin't always correct.
Bret
Old Dec 7, 2006 | 12:10 AM
  #71
turbo_Z's Avatar
Bret
And by that I am assuming you comparing the 311x lobes with the 331x lobes?
Old Dec 7, 2006 | 12:23 AM
  #72
Actually in a lot of instances it goes thru the whole line and not always the same lobes in the same familys fit the rules or the applications.
BTW there is not even a 314X lobe in there.... but I get what your saying. I don't comment on particular lobes but the measurement of the lobes is not easy to do simply enough where I can just give you the HOW to do it.
You gotta look at all the lobe specs and what they are relative to each other, that's the key. If one thing is way off say lift or duration at a certain spec it can throw EVERYTHING out of wack.
Bret
Old Dec 7, 2006 | 11:07 AM
  #73
Colin91Z's Avatar
Not to hijack the thread any more, but since you're talking about mods on Impala heads I figured that I'd let ya know that I have a pair of bare unmolested Impy heads sitting in my garage that I'd like to get rid of if your interested....if so, PM me
Old Jan 9, 2007 | 01:43 PM
  #74
96 mikez28's Avatar
I was really into the cc306 but i really don't want to rev that high, the more i look into the 503 the more i like it
Old Jan 9, 2007 | 08:38 PM
  #75
Mortify's Avatar
So what exactly does LSA provide... lower or higher RPM range of power, the deep exhaust sound...?
