11:1 Cr
Old Apr 29, 2005 | 10:40 PM
96ta(nick)'s Avatar
11:1 Cr
How much do i need the heads milled and what gaskets should i use to get to around 11:1 CR with my stock ported heads and stock bottom end? And with that will i need my intake milled to match or will i be ok with how it is?
Nick
Old Apr 29, 2005 | 10:46 PM
turbo_Z's Avatar
Re: 11:1 Cr
Impalla head gaskets will bump up 10.5:1 to 11.0:1. Why do you want the extra compression? I think there is only around a 2% hp gain.
Old Apr 29, 2005 | 11:35 PM
Alvin@pcmforless.com's Avatar
Re: 11:1 Cr
extra compression is a great way fo building extra torque and HP.
Your going to have to have you heads decked a bit for that. Make sure they check the intake after they cut the heads. We've been having a few leaky intakes lately.
Old Apr 29, 2005 | 11:37 PM
96ta(nick)'s Avatar
Re: 11:1 Cr
Hey every little bit counts
And how much do i need them cut down?
Old Apr 30, 2005 | 10:44 AM
Jeff95TA's Avatar
Re: 11:1 Cr
You can also try the Mr. Gasket head gasket - it's a little thinner then the Impy. I think .026
Old Apr 30, 2005 | 12:56 PM
1racerdude's Avatar
Re: 11:1 Cr
Nick
Depends on how far your piston is downhole,CC's of valve reliefs and chamber size and gasket bore size and thickness.
Generally about .008-.010=1CC in chamber size when ya cut the heads.
Old Apr 30, 2005 | 02:00 PM
Don 97 SS's Avatar
Re: 11:1 Cr
I have the impy gaskets that are .028" and my heads were milled .010" for about 11:1.
Daluchman1974
Sep 11, 2015 06:12 AM
mrwz28
Jul 8, 2015 09:11 PM
TitoPR221
May 26, 2015 12:20 AM
racer1
Sep 21, 2003 11:22 AM
1994CamaroZ
N2O Tech
Dec 29, 2002 01:39 AM
