10hp more in the 97?
Old Sep 24, 2003 | 07:45 PM
  #16
SSnakeEater's Avatar
the LT1 vettes are rated at 15-25 more horsepower than the lt1 fbodies because of a larger airbox/filter, bigger MAF, intake elbows, headers and mufflers. (maybe slightly bigger TB but im not sure) that is all, besides that nothing is different, same exact engine!!! i love pulling up to an extremley cocky lt1 vette driver and giving him a REAL run for his $$$ !
and a question about the dual cats on the 96-97's
- why in gods name would ADDING a cat increase horsepower? are they two higher flowing cats???
Old Sep 24, 2003 | 08:01 PM
  #17
lt1hatesme's Avatar
if all they had was that... than you could take a vette maf (bigger??) and plug it right into your fbody and it should work better than the stock one right?
Old Sep 24, 2003 | 09:04 PM
  #18
S.J.S.'s Avatar
Nope. That's the only diff. It's the same car except for the fact that its the 30th anny model lolol.
Old Sep 24, 2003 | 09:59 PM
  #19
nateh's Avatar
The difference in the hp rating was due to the less restrictive y-pipe produced for OBD2 requirements in '96. There may have been a different head casting number for some vehicles those years, but I don't believe the cars were rated by taking that difference into account.
Old Sep 24, 2003 | 10:20 PM
  #20
97bowtie's Avatar
All '96 and '97 cars DO have different head castings and they do flow slightly better than '93-'95 castings. However, I believe GM rated the cars 10 hp higher was due to the less restrictive design of the dual-cat y-pipe. '96 and '97 cars also have slightly different cam specs...but then again, so does every year of LT1 f-bodies.
Old Sep 25, 2003 | 01:44 AM
  #21
QCKZ28's Avatar
so your saying all 96 and 97 lt1's got the 571 casting?
Old Sep 25, 2003 | 08:23 AM
  #22
BitCypher's Avatar
Where's the casting number on the heads? If it's fairly visible I'll look at my '96 and see what casting it is using. Of course, my luck says the casting number is under the valve cover, right?
Old Sep 25, 2003 | 11:30 AM
  #23
LT4Firehawk's Avatar
TB was the same on LT1 vettes, as well as the MAF. The differences were:
larger airbox w/straight air intake path
MUCH better exhaust manifolds, almost as good as shorty headers
true dual exhaust
Old Sep 25, 2003 | 09:23 PM
  #24
97bowtie's Avatar
'96 and '97s have 561 castings.
MadMav
Jun 8, 2015 11:38 PM
ph95firehawk
Apr 26, 2007 05:06 PM
black02z28
Jul 28, 2005 11:41 AM
blackztpi
Jan 9, 2005 12:13 PM
