10hp more in the 97?
Old Sep 24, 2003 | 02:13 PM
wayne97's Avatar
Why does the 97 LT1 fbody engine rate @ 285 hp and the other years at 275 hp .... what did they change to get that - does anyone know???
Old Sep 24, 2003 | 02:14 PM
Camaro_Maniac63's Avatar
The dual cat setup on the 97s is supposedly good for that additional 10hp...
Old Sep 24, 2003 | 02:21 PM
wayne97's Avatar
so the engines are identical??
Old Sep 24, 2003 | 02:22 PM
GREGG 97Z's Avatar
Re: 10hp more in the 97?
They also had a little different head castings, which flowed slightly better, around 3% I've heard.
Old Sep 24, 2003 | 02:28 PM
wayne97's Avatar
the greg97 thats exactly like my car in your pic and I've got basically the same set up at you - except mines an A4. I work in morgantown right down the road from you ...
Old Sep 24, 2003 | 02:45 PM
BUBBA's Avatar
Why would they have different head castings? First I've heard of that...JMHO
Old Sep 24, 2003 | 02:48 PM
BitCypher's Avatar
The 96-97 f-bodies had dual catalytic converters, which supposedly upped the power by 10hp. I've never head of a difference in the head castings, other than the Impala LT1 had iron heads and the f-body LT1 had aluminum.
Old Sep 24, 2003 | 02:54 PM
GREGG 97Z's Avatar
I don't know why they would, but they do. They are a lighter casting with slightly better flow on the intake I beleive. There are two different LT1 head castings, I think the numers are #561 & 571.
Wayne, sent you a pm.
Antz97ZNJ's Avatar
never heard the head casting thing either...the dual cats is basically 10 hp on paper ...never saw any noticable differance in performance from any other years
Old Sep 24, 2003 | 03:14 PM
wayne97's Avatar
i figured this would have been discussed quite a bit in the past ...
looks like ive started some trouble....
Old Sep 24, 2003 | 03:16 PM
GREGG 97Z's Avatar
Do a search on it, it's been discussed. Lloyd Elliot has mentioned the difference a few times, he actually prefers the older castings though for extensive porting because there is more material to work with in those heads, you can't port the lighter castings as much. The change may include 96's as well but I know I've heard they are different on 97's. I'm not trying to say there was any huge difference in them but they are different.
Old Sep 24, 2003 | 06:08 PM
DSIM's Avatar
I have heard that the 96-97's have a different cam.
Old Sep 24, 2003 | 06:24 PM
lt1hatesme's Avatar
can anyone answer this?? why is the corvette LT1 rated @ 300 hp?? whats different between those two (fbody, corvette)?
Old Sep 24, 2003 | 06:33 PM
ibanez6rg's Avatar
Intake & exhaust
I've also heard about the different castings...
Old Sep 24, 2003 | 07:16 PM
lt1hatesme's Avatar
Originally posted by ibanez6rg
Intake & exhaust
thats it?? no different programing for a more aggressive car, or anything else?
