10 mpg after hot cam
Old Mar 27, 2004 | 12:30 AM
JJ's95B4C's Avatar
Is this normal? I have programming from PCMforless, and new plugs and wires. Should I get a new o2 sensor? I had a blown head gasket and was burning coolant. I was getting 15-17 mpg before the cam. Thanks for the help.
Old Mar 27, 2004 | 12:35 AM
LT1Brutus's Avatar
No, that is not normal.....though a lot depends on your drving. If the gas pedal never comes off the floor...yeah, you'll get crappy gas mileage. A lot of guys complaining of horrible gas mileage after a major mod don't factor in that they're now giving their friends 8-9 "around the block" WOT rides a day showing off the new power....
That being said, my LT4HC, 3.73 geared, 3,000 stall, stage II head motor even with my incredibly heavy foot averaged 16.7 mph....quite a difference from yours.
I'd recommend talking to Brian about sending him some "logs" of you running around town...hope you have a laptop and cable and letting him see what is going on. Bryan is great at that type of diagnosis
Old Mar 27, 2004 | 12:42 AM
JJ's95B4C's Avatar
I thought that was my problem the first time, but for the last week i've been driving without crossing 2K rpms, seriously. Its been hell, but i really wanted to see what is going on. I'll log a couple runs on Datamaster and send them to Bryan. I hope he doesn't charge me more! lol
Edit...I do have an exhaust leak, but i'm pretty sure its on the passenger side collector, and thats after the o2 sensor.
I Just looked at a log of Datamaster I did, and my BLM's are at 128 for both sides at WOT, and the o2's are in the 900's. I'm guessing its the part throttle tuning that needs help then, right? Will VE master help me out, or is that for 93 cars only?
Old Mar 27, 2004 | 03:17 AM
RE AND CHERYL's Avatar
Cool
Coolant will destroy your O2 sensor.
Old Mar 27, 2004 | 06:17 AM
97Camaro007's Avatar
Seems like my car doesn't get much more than 10-12 mpg right now either.....i do have an exhaust leak behind the 02's as well.....might have an exhaust leak before because of the slip in tube that goes around the steering knuckle......
Old Mar 27, 2004 | 01:16 PM
97 RedSS's Avatar
Weld that bitch up and it wont leak
Cody
Old Mar 28, 2004 | 12:39 AM
yeah i need to.....Cody, when am i going to see your car dude.....I live right down the road now......I want to see that stroker car!
Old Mar 28, 2004 | 12:06 PM
LT1Brutus's Avatar
part throttle and that exhaust leak are part of your problem. I had a damaged flange on my header and I thought it wouldn't effect o2/ exhaust flow too badly either. Well, I went through the process of trying to fix it like 5 times before I finally got it right and I can say that it was absolutely worth 3mpg.
jj_burchiel
Mar 5, 2015 07:05 AM
djangoroar
Parts Wanted
Feb 21, 2015 11:47 PM
GigaMp3z
Feb 20, 2003 02:57 PM
Smokn '94 Z
Aug 4, 2002 06:11 PM
Smokn '94 Z
Jul 28, 2002 02:38 AM
