1.6rr
Old Apr 1, 2010 | 10:07 PM
z28beast's Avatar
1.6rr
what all is required to do the swap from stock to 1.6rr??? and what type of gains am i looking at? also how much in parts is it usually if i do all the work?
Old Apr 2, 2010 | 07:55 AM
RamAir95TA's Avatar
New rockers and valve springs at the least. Many guys use the LT4 valve springs (which reuse factory retainers, locks, and seats). You'll also need to trim the interior of the valve covers to clear the 1.6s. A good set of rockers are $300+.
Typical gains are around 10-12hp.
Old Apr 2, 2010 | 08:04 AM
Kevin Blown 95 TA's Avatar
If you did springs as suggested, it would be about $400 give or take. Going to a full roller rocker from the stock stamped pieces is one of the best bolt-on modifications IMHO. You lose friction, heat, and imprecision, and get more valve lift in the process. The new springs will make the swap a lot harder, but yours were probably shot a long time ago, and that will seem to wake up your engine as well.
You may or may not have to trim your valve cover supports a bit, some do and some don't.
Old Apr 2, 2010 | 09:31 AM
19z28camaro02's Avatar
I just picked up my 1.6RRs yesturday, $325 just for the rockers.
Old Apr 2, 2010 | 09:38 AM
z28beast's Avatar
ok soo i noticed there are like lots of different rockers made by comp cams...i like the aluminum full roller rockers...are these good? whatta you guys reccomend?
Old Apr 2, 2010 | 10:04 AM
wrd1972's Avatar
I prefer the pro-mag chromoly rockers over the aluminum. They are stronger than aluminum.
Old Apr 2, 2010 | 10:08 AM
z28beast's Avatar
ok so what kind do i need s/a or ns/a...i plan on eventually putting in a comp cams 305 in it if thats any help.. and also eventually rebuilding to a 383 stroker
Old Apr 2, 2010 | 01:16 PM
tapout911's Avatar
You can run a 3/8 stud S/A rocker and not have to upgrade to 7/16 studs and guideplates. IMO if youre gonna change springs, might as well go studs and guideplates whiles its apart.
So heres a list:
1.6 pro mag non sa
7/16 studs
GM guideplate or isky adjustable
Valve springs
You used to be able to by a crane 10308 valve spring set the was perfect for this swap. Not sure on its availability anymore.
Old Apr 2, 2010 | 10:01 PM
z28beast's Avatar
So heres a list:
1.6 pro mag non sa
7/16 studs
Valve springs
ok cool man thanks for the help
QCKZ28
Jan 18, 2007 02:23 PM
stevil
May 5, 2003 09:47 PM
scyzoryk
May 3, 2003 10:54 AM
Like2gofst
Apr 17, 2003 06:34 AM
Got-LT1
Mar 17, 2003 10:49 PM
