Starting wierd
Old Apr 1, 2010 | 11:20 PM
94Phoenix's Avatar
Starting wierd
my 94 formula has been starting odd lately. ill turn the key and it will act like its gonna start, then completely stop...and then fire right up. is this the beginning of the battery going bad? shouldnt be the starter cuz it was rebuilt about a year ago
but sometimes it will start perfect though
Old Apr 2, 2010 | 07:42 AM
craby's Avatar
are u saying the starter actually stops turning the motor and while still holding the key to the start position it starts turning the motor again?
Old Apr 2, 2010 | 12:50 PM
94Phoenix's Avatar
exactly. the battery whines down to nothing. and then it turns again and starts
Old Apr 2, 2010 | 12:59 PM
RamAir95TA's Avatar
Battery cables/terminals. Sounds like an inconsistent connection.
Old Apr 2, 2010 | 01:44 PM
craby's Avatar
^^^ yep take the battery cables off and wire brush the heck outa them and the terminals on the battery. also take the wires to the power junction box ( red plastic box on the passenger wheelwell) off and wire brush the heck outa them and put them back. have a look at the ground junction next to the power junction. if that doesnt work check your grounds that go to the block. theres one by the belt idler, one by the starter and one on the front of the block on the driver side .
Old Apr 2, 2010 | 11:13 PM
94Phoenix's Avatar
thanks for the input man. looks like im gonna do some scrubbin!
Old Apr 3, 2010 | 12:21 AM
craby's Avatar
u bet... add to the list,,,make sure the starter bolts are not lose (thats how the starter grounds) and while your down there check the main wire to the starter. thats all i can think of.
Alex Barnes
Jan 24, 2015 10:21 PM
Amshnock
14
Jan 18, 2015 11:47 AM
Black Sunshine/ 00SS
Aug 24, 2002 03:41 PM
Hot Rod Hawk
Aug 15, 2002 10:47 PM
formula79
Jul 13, 2002 09:06 PM
