Tuning for 1.6RR
Old Apr 13, 2003 | 02:48 PM
stevil's Avatar
Tuning for 1.6RR
I have Tunercat, and just did 1.6RR and valvesprings. I'm sure I can tune something for them, what tables should I try editing?
Old Apr 14, 2003 | 04:44 PM
mtxpert's Avatar
I can't imagine editing anything as the computer will see the additional air in/out via MAF and O2 sensors. You might be slightly leaner on the top end so you should check your AFR with a wideband O2 at WOT. Compensate via PE tables - fuel vs RPM.
Hope this helps.
Mike
Old Apr 15, 2003 | 11:00 AM
JSK333's Avatar
You may do well with increased timing in the lower RPMs as well.
Old May 5, 2003 | 09:47 PM
QCKZ28's Avatar
i had this same question as well, i have pcmforless and i emailed brian and asked him, he said that the maf would "sense" the increased airflow and compensate for it, and no tuning was needed.
jesse
Aug 24, 2015 06:41 AM
sherwinZ28
11
Aug 15, 2015 05:38 PM
RallyRed701/2
Jul 27, 2015 02:55 PM
colts0455
Jul 24, 2015 04:51 PM
Shookiez28
Jul 23, 2015 01:55 PM
