1.6rr?
Old May 31, 2005 | 02:02 PM
Nick-LT1's Avatar
1.6rr?
I think my next mod will be 1.6rr. What will i all need? What kind of springs should i use? I plan on doing a cam down the road just not right now.
Old May 31, 2005 | 02:13 PM
sssalah's Avatar
Re: 1.6rr?
Poeple have run 1.6 rr with stock springs, but that's too risky IMO, LT4 spring kit is a good and cost effective. If you have your mind set on a cam now, then go with whatever springs are recommended for this cam, otherwise LT4 springs.
Old May 31, 2005 | 02:21 PM
Compstall's Avatar
Re: 1.6rr?
Definitely figure out what cam you want to use, then use the springs for it as mentioned. WILL save time down the road.
Old May 31, 2005 | 02:22 PM
OBE1 95Z28's Avatar
Re: 1.6rr?
Good time to replace the valve seals while you have the springs off.
QCKZ28
Jan 18, 2007 02:23 PM
stevil
May 5, 2003 09:47 PM
scyzoryk
May 3, 2003 10:54 AM
Like2gofst
Apr 17, 2003 06:34 AM
Got-LT1
Mar 17, 2003 10:49 PM
