Car wont start!!!!!
Old May 31, 2005 | 08:23 AM
gamecockfan04's Avatar
Car wont start!!!!!
It rained all day yesterday and my car sat from Friday night till this morning. So, I went too start my car this morning and as I turn the key I hear a load clunk, now it did this same thing a few weeks ago after it rained then fired right up, so I tried again and it momentarily started but really rough for about 3 seconds and it cut off. Then I tried again and it turns over but will not fire. I checked fuel pressure and its fine(42 PSI). Sometimes when Ill try and start it Ill hear a clunk from underneath the engine(at least thats where I think it is). Does thios sound like the Opti? As far as I know its the stocker and Im at 123K. Ive got plugs with less than 3K on them and wires as well. Any Ideas on what I can do? I pulled the Elbow off and I can see little puddles of water on the intake.
Old May 31, 2005 | 08:39 AM
30696bird's Avatar
Re: Car wont start!!!!!
The clunking sounds like a starter issue to me. And the no starting sounds like a opti issue. Watter puddling up in the intake??? That's not good........maybe the CAI is getting water in it somehow? These are just online guess's but that's what it sounds like to me.
Old May 31, 2005 | 11:18 AM
OK, I checked my car with Freescan and Ive got a code #16 LO-RES Failure. Anybody know what that means?
Old May 31, 2005 | 11:30 AM
30696bird's Avatar
Do a search for low resolution.
Old May 31, 2005 | 02:00 PM
Alrighty, its gotta be the Opti!!! I pulled the coil wire and its firing, but there's no fire at the plugs. Where can I get one? Sam Taylor, GM Partsdirect? Any install guides? And how tough/long of a job is it.
Old May 31, 2005 | 02:26 PM
WildThing94Z's Avatar
I would get one from Dal or Jason Cromer . . . I believe that their contact info is on Shoebox's site . . . along with info on the swap.
Changing the opti is a piece of cake, and can be done from the top without jacking the car up. Basically all you are doing is removing the waterpump to access the opti. It should not take you more than a few hours since it's your first time.
Pete
Noenav
Mar 1, 2019 07:38 AM
97SSdude
Dec 31, 2014 07:43 PM
tds1213
Nov 27, 2014 12:55 PM
USAirman93
Nov 24, 2014 03:37 PM
Dave19yz28
Jan 26, 2003 01:45 PM
