? on 1.6 rr
? on 1.6 rr
hey everybody i had one quick question . . to install 1.6 rr all i need is springs and the rr right???if i need something else let me know . . i just want to make shure thats all i need to buy . . thanks for checking out my post
Originally posted by 12SCNDZ
As long as they're Self Aligning rockers you're OK. I know guys using 1.6's with the stock cam, and stock springs.
Frank
Frank
I would be one of those guys. Almost 10k miles on 1.6rr and stock springs, not problems. Hell, I drove the car to Florida with them!
what are the lift numbers on the stock springs? not that i would want to keep them or anything, but i was curious if they could handle the extra lift that would come along with the 1.7 rr's on a stock cam???
Yeah even with the 1.6rr's you are pushing it. With 1.7's there is no way. Sidewayz did you finally decide on the 1.6's? I'm gonna probably go with the 1.7's. What made you decide on the 1.6? Also if you get Non SA then you need hardened pushrods and guideplates.
do they have sa 1.7 rr ?? . . i want the 1.7 but id have to get alot of parts just to do it . .with the 1.6 id just have to get springs a rr . .but im not shure yet im 50%1.6 . .50%1.7 . . so what do you guys think id be better off doing?? drew you going with 1.7?? let me know what parts you are getting . .thanks for checking my post out been a good help
The only other parts that you need with Non Sa over the SA's are just the guideplates that i know of. When i found out i had to get more parts to do the NSA rockers i decided on SA's but then i was told that there isn't much to it to install the guideplates at all. Also they are a little better then SA rockers, and not as noisy. Yeah i'm gonna go with the 1.7rr's for now. Later on when i do a cam i'll probably keep the 1.7s because i'm probably gonna go with the 224/230xe, but if not i'll just swap them out for 1.6rr and sell them. At least i will get a little better gain for now.
Here is a good parts list at the bottom post on this page.
http://web.camaross.com/forums/showt...5&pagenumber=1
Here is a good install guide.
http://www.streetillusionsracing.com/RR/rr.htm
