? on 1.6 rr
Old Oct 22, 2003 | 09:24 PM
SiDeWaYZz28's Avatar
? on 1.6 rr
hey everybody i had one quick question . . to install 1.6 rr all i need is springs and the rr right???if i need something else let me know . . i just want to make shure thats all i need to buy . . thanks for checking out my post
Old Oct 22, 2003 | 09:46 PM
12SCNDZ's Avatar
As long as they're Self Aligning rockers you're OK. I know guys using 1.6's with the stock cam, and stock springs.
Frank
Old Oct 22, 2003 | 09:51 PM
thanks for the reply i just wanted to make shure
Old Oct 22, 2003 | 10:15 PM
Got-LT1's Avatar
Frank
I would be one of those guys. Almost 10k miles on 1.6rr and stock springs, not problems. Hell, I drove the car to Florida with them!
Old Oct 23, 2003 | 01:59 AM
yea im going to make shure i get springs.
Old Oct 23, 2003 | 09:44 AM
Fuels94TA's Avatar
Also do the push rods as well since the old one might have some miles on them.
Vinny
Old Oct 23, 2003 | 10:21 AM
RallyRed701/2's Avatar
what are the lift numbers on the stock springs? not that i would want to keep them or anything, but i was curious if they could handle the extra lift that would come along with the 1.7 rr's on a stock cam???
Old Oct 23, 2003 | 10:22 AM
Got-LT1's Avatar
I doubt it, my 1.6s are on stock springs and are close to the limit.
Old Oct 23, 2003 | 10:26 AM
drewstealth's Avatar
Yeah even with the 1.6rr's you are pushing it. With 1.7's there is no way. Sidewayz did you finally decide on the 1.6's? I'm gonna probably go with the 1.7's. What made you decide on the 1.6? Also if you get Non SA then you need hardened pushrods and guideplates.
Old Oct 23, 2003 | 02:17 PM
do they have sa 1.7 rr ?? . . i want the 1.7 but id have to get alot of parts just to do it . .with the 1.6 id just have to get springs a rr . .but im not shure yet im 50%1.6 . .50%1.7 . . so what do you guys think id be better off doing?? drew you going with 1.7?? let me know what parts you are getting . .thanks for checking my post out been a good help
Old Oct 23, 2003 | 02:33 PM
The only other parts that you need with Non Sa over the SA's are just the guideplates that i know of. When i found out i had to get more parts to do the NSA rockers i decided on SA's but then i was told that there isn't much to it to install the guideplates at all. Also they are a little better then SA rockers, and not as noisy. Yeah i'm gonna go with the 1.7rr's for now. Later on when i do a cam i'll probably keep the 1.7s because i'm probably gonna go with the 224/230xe, but if not i'll just swap them out for 1.6rr and sell them. At least i will get a little better gain for now.
Old Oct 23, 2003 | 02:52 PM
so with 1.7 all i need is the rr,springs.harden pushrods,guide plates?? is that all?
Old Oct 23, 2003 | 02:58 PM
Here is a good parts list at the bottom post on this page.
http://web.camaross.com/forums/showt...5&pagenumber=1
Here is a good install guide.
http://www.streetillusionsracing.com/RR/rr.htm
Old Oct 23, 2003 | 03:04 PM
thanks drew just what i needed thanks for the links big help
13qtr
Oct 28, 2016 08:11 PM
95chwagon
Oct 16, 2015 12:24 PM
football4life
Oct 4, 2015 07:48 AM
9t4lt4z28
Oct 2, 2015 10:28 AM
MDZ28
11
Sep 24, 2015 09:15 AM
