1 5/8 Primary Headers
Old Nov 29, 2003 | 02:11 AM
  #16
TheHeadFL's Avatar
Let me quote a more reputable source:
The first thing to consider is the size of the primary tubes. Bigger tubes will give better breathing for top-end power, but the low velocity at lower rpm will make for more reversion to contaminate the next charge, so larger tubes will usually cost some low-end power. It is a common mistake to port the heads to match the headers primary pipes, but this does more harm than good. The primary tubes should be larger than the exhaust ports, this makes a reversion dam to limit reverse flow.
The shorter the primary tubes are the higher in the rpm range they will help power. Each exhaust pulse causes a high pressure wave to travel toward the collector. When it reaches the collector it is inverted and travels back toward the cylinder as a low pressure wave. It is this low pressure area that helps scavenge exhaust out of the cylinder during the overlap period. This happens when the low pressure area reaches the exhaust valve during the overlap period. The low pressure area helps draw out the exhaust and draw in more fresh intake charge. All the pressure waves travel at the speed of sound (1200-1300 ft/sec in the hot exhaust). With all the pressure waves traveling at a constant speed, you can see that the header can be only be tuned to a narrow rpm range. On a street car that needs low-end, the tubes should be longer, in a high rpm drag car they will need to be much shorter. To get you close to the optimum primary tube length, use this formula:
Length (in inches) = (CID x 1900) ÷ (rpm x pri.OD2)
from: http://www.grapeaperacing.com/GrapeA...ustheaders.cfm
First site I found on google about header primary tech. Draw your own conclusions.
Old Nov 29, 2003 | 07:38 AM
  #17
12SCNDZ's Avatar
Originally posted by ibanez6rg
You can get all the emission BS with JetHot longtubes. If you're building up a car, LTs will do best. Otherwise, stock motor... not really sure. Losing HP at top-end with LTs?? Defiantly not! Losing torque on the bottom-end, more like.
You've got that backwards...Mid lengths build more top end HP. LT's build more low end torque. It's a FACT not an opinion.
Check out any dyno tests comparing the 2 headers. Car Craft just did yet another one last month. The mid length headers blew the longtubes away in the top end HP department.
I really don't think my car is too close to stock, either.
Frank
Old Nov 29, 2003 | 07:45 AM
  #18
12SCNDZ's Avatar
I see you've got more cam than I do + longtubes...Mind if I ask what your car runs?
Frank
Old Nov 29, 2003 | 07:52 AM
  #19
Smokn '94 Z's Avatar
Frank
Dam. I was just looking at your sig. Your race wt is only 3448 with you in it? And with your seats? That is nice. I wieghed in at 3595 with no seats or spare with me in it. I weigh 200 lbs. Nice times. What stall is your converter?
Old Nov 29, 2003 | 10:48 AM
  #20
ibanez6rg's Avatar
Frank
No times, I will in the spring after my head swap.
I'll still have to disagree with you though - LTs shine on top-end, my car pulled so much harder after the install. With the exhaust I'm running I have very little backpressure. The reason I say this is, LTs will flow much better at higher RPMs. They allow the engine to breath more. I'm not going for anything more than a high 11 second car.
Old Nov 29, 2003 | 12:07 PM
  #21
ChrisUlrich's Avatar
Yo
If LT increase top end, than shorties/mid lengths are useless? Well, not useless but not as effective as Long Tube because LT's add high end power while Firebirds already have a tremendous amount of torque?
I'm still curious about the difference in hp and torque gains from 1 5/8 primaries to a set of long tubes... if its a big difference or not.
Chris
Old Nov 29, 2003 | 12:10 PM
  #22
Ace_437's Avatar
Yo yo yo, man!
Old Nov 29, 2003 | 03:59 PM
  #23
TheHeadFL's Avatar
*cough* 1 3/4" primary tubes and larger radius gently sloping mandrel bends. *cough*
Seriously, LONG TUBE HEADERS will generally make more top end HP than a 1 5/8" shorty/mid PROVIDING they have 1 3/4" primaries. The larger primaries make up for the loss of top end from the longer tubes.
Old Nov 29, 2003 | 04:38 PM
  #24
Antz97ZNJ's Avatar
Why does everyone push longtubes? Do you all like the idea of LOSING top end HP?
Frank
If you want to continue doing more and more mods you dont wanna choke up your set up w/ a set of shorties....on a bolt on car shorties are fine if you plan on leaving it like that, but even then the long tubes will give you an additional 10 hp over the shorties...The top end loss isnt enough to actually worrry about
Old Nov 29, 2003 | 05:52 PM
  #25
drewstealth's Avatar
Yeah 12SCNDZ your car does have some great times for what it has but you would honestly gain some more power with some better flowing headers, like AS&M's mid-lengths, or long tubes. The Macs are very nice headers but they are better when used on a bolt on car.
Old Nov 29, 2003 | 07:56 PM
  #26
To answer the original question, the JBA's are 1-5/8" "shorties". On top of that, they are a "step" header design. The first couple inches of each primary is only about 1-1/2". The theory is that the higher primary tube velocities aid scavengeing at low RPM. This works.... the JBA's provide excellent low end torque on a basically stock engine, but if you make any sort of breathing improvements at all, the stepped, small diameter primaries are going to kill you. I had them when my car was a "bolt on"... and they strangled the top end. The JBA's also seem to have added a weld bead to the flange port, as an "anti-reversion" measure. That further choked the flow at high RPM.
If you are serious about long term improvements for major power, invest in either a good set of Hooker LT's, or the AS&M mid-lengths. I have seen both support LT1 engines in the 800-1,100HP range.
Old Nov 29, 2003 | 09:24 PM
  #27
Yo
Hey thanks... about time someone answered it... haha j/k
Nah, I just want to be in the 320-350 range. I was told the car dynoed at 319hp but it seems shaky to me, I don't know why... A stock Formula with the JBA Headers, tri-flow exhaust, random tech cat converter, lingenfelter cold airtake charger, and... I think thats it. Doesn't 319 sound high?
Chris
Old Nov 29, 2003 | 09:47 PM
  #28
crAzy95z28's Avatar
yea what about the AS&M headers PEEEEEEEEEEEOOOOOOOOOOPPPPPPPPPPPLLLLLLLLLLEEEEEEE EE?????????????
woont those blow the LT's away?
Old Nov 29, 2003 | 10:53 PM
  #29
12SCNDZ's Avatar
My 9.5" converter is rated at 3800 stall. I had a 10.5" 3200 stall in it, but it wasn't enough for the CC305/ported heads. I dropped from a 1.77 60 ft. to a 1.67 with the 9.5".
My car is a very little optioned car...standard windows, locks, and no t-tops...About the only options mine had were factory 3.23's and cruise control. Yes, I still have all the seats, A/C, P/S, and bumper supports...I weigh 190#.
Frank
Old Nov 29, 2003 | 11:03 PM
  #30
Steve0's Avatar
Originally posted by ChrisUlrich
Yo
Chris
Yeah, 319 seems way too high. I would think youd be closer to 280rwhp give or take.
