1/4 mile
Old Mar 6, 2010 | 07:30 PM
streetfreak's Avatar
1/4 mile
1995 camaro z28 6-speed
What do you guys think my car will run with this done?
Built a LT1 383 stroker
flowmaster cat back system with BBK headers and Y pipe
eagle stroker kit (pistons, H beam rods, crank, rings) comp cams cam,roller
rockers and lifters.
the crank is Forged Steel, Pistons are flat top forged aluminum 11:1 compression ratio with the heads.
I had the computer programed at FastChip in Tulsa Oklahoma
4:10 gears
The throttle body has an airfoil installed in it that decreases
turbulance
Old Mar 6, 2010 | 07:40 PM
"Built LT1 383 stroker" is sort of vague.
What heads, what flow numbers?
What cam specs (besides "comp cams)?
What ratio roller rockers?
Are the BBK's 1-5/8" shorties?
Do you have a CAI?
What size throttle body?
What size injectors?
Old Mar 6, 2010 | 07:42 PM
96SSIndeed's Avatar
with everything Injuneer said as well as how go you can drive a stick
Old Mar 6, 2010 | 07:52 PM
Do you have a CAI?
bbk shorties
stock injectors and tb
no cai
im not sure on the numbers bought it like that
Old Mar 6, 2010 | 08:01 PM
Well..... with stock injectors, you are going to be at 100% duty cycle at 425 flywheel HP, putting you at about 365rwHP. Generally, its not a good idea to go over 90%, which would limit you to about 380 HP at the flywheel = 325rwHP. With no CAI, your air intake will be choked. With the 1-5/8" BBK shorties, the exhaust will be limiting. Engine can't breathe.
Assuming you have something beyond stock heads, and something larger than an LT4 HOT cam, you might run mid-12's at 110 MPH.
RamAir95TA's Avatar
Then unfortunately no one can give you an accurate estimate. Take it to the track/dyno and see how it does.
Old Mar 6, 2010 | 08:09 PM
just stock heads and the lift on the cam is a .510 the guy i bought it off of said he ran it once and went a 12.7
and what if i stick a cat on it?
3inch from headers back
Also the tune called for stock injectors idk y
O and it has a functional ram air hood with ls1 type air box and K&N air filter
Old Mar 6, 2010 | 09:01 PM
STRYKER's Avatar
A lot of your time will come from if you can REALLY drive a stick. For instance, put me and a buddy of mine in the same exact 6 speed car and I guarantee that he will get the better time and mph. And I know how to drive a stick pretty well. It is just that he is a bit better at racing with a stick than I am. PS. Don't tell him I said that either lol.
Old Mar 7, 2010 | 09:20 AM
If you have stock heads and a mild cam, a 383 isn't going to make much more than a stock LT1. He's lucky if he ran 12.7
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
D1SC383LT4
Jan 1, 2016 01:56 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
jayblev95
Track Kill Stories
Jan 15, 2015 07:48 AM
