¿Opti Question?
¿Opti Question?
My car will not start right now but I'm getting spark at the plugs.
I only checked one wire though.
If my opti is bad will I still get spark at the plugs?
If it will spark, then will the bad opti make my car not start at all because of the timing? Maybe the optical part is messed up?
Car's not running trying to figure out why.
Re: ¿Opti Question?
http://web.camaross.com/forums/showthread.php?t=323436
Don't forget to check to see if you have any fuel pressure.
Re: ¿Opti Question?
It's a 96.
How do I check to see if the chain have jumped time?
Is there a way to check to see if the opti is bad without having to remove the water pump and the opti?
Sergio
Jan 27, 2016 04:27 PM
IgorT.455/406
Mar 12, 2015 03:39 AM
