¿Opti Question?
Old Dec 20, 2004 | 12:39 AM
Hood_Lum's Avatar
¿Opti Question?
My car will not start right now but I'm getting spark at the plugs.
I only checked one wire though.
If my opti is bad will I still get spark at the plugs?
If it will spark, then will the bad opti make my car not start at all because of the timing? Maybe the optical part is messed up?
Car's not running trying to figure out why.
Old Dec 20, 2004 | 03:31 AM
GreenDemon's Avatar
Re: ¿Opti Question?
http://web.camaross.com/forums/showthread.php?t=323436
Don't forget to check to see if you have any fuel pressure.
Old Dec 20, 2004 | 07:08 AM
RE AND CHERYL's Avatar
Re: ¿Opti Question?
If the fuel pressure is good and you've got spark. The timming chain may have jumped time. How old is it?
Old Dec 20, 2004 | 11:46 PM
Hood_Lum's Avatar
Re: ¿Opti Question?
It's a 96.
How do I check to see if the chain have jumped time?
Is there a way to check to see if the opti is bad without having to remove the water pump and the opti?
Sergio
Jan 27, 2016 04:27 PM
IgorT.455/406
Mar 12, 2015 03:39 AM
grgguy
17
Feb 23, 2015 07:57 PM
Injuneer
Dec 15, 2014 09:36 AM
pologreen97z
Dec 2, 2014 10:42 AM
