Is z28s spoiler useful???
Old Feb 18, 2004 | 07:15 PM
  #31
Rogue Leader's Avatar
Originally posted by Lucas Black
doesn't the g35's have something along those lines engineered into the belly of their cars? maybe not something as thorough, but following the same sort of guidelines....
I believe they seal and smooth the gaps between the framerails and the front and rear bumpers, that can make a HUGE difference as much less air would be trapped under the car...
Old Feb 18, 2004 | 09:12 PM
  #32
Gone4Day's Avatar
Originally posted by supercrosser
Since people are discussing wings on other vehicles, I did not see anyone mention the vehicles that had one of the best spoilers in history. The Dodge Daytona and the Plymouth Superbird. These cars had spoilers about 2 feet high and were taller than the car. These spoilers by being huge worked very well with the car. I just didnt want people to forget about those two spoilers.
The reason the wing was so high on the Superbird and Daytona was so the trunk could be opened. Otherwise, it could have been half the height. Most rear spoilers are useless, but in some cases they serve a purpose. On some cars a rear spoiler decreases drag by separating the air flow from the body. In other cases they are there to counteract lift at the rear end which can make a car oversteer at high speed. The Audi TT comes to mind. When it first came out there was no spoiler, and owners were swapping ends at high speed - not good if you want repeat customers. So subsequent models have a rear spoiler to maintain neutral balance at speed.
Same with front spoilers, they don’t generate downforce so much as the prevent lift. I’ve driven a few cars without front spoilers, that, due to there front end styling, generated a fair amount of front end lift at high speed. Very unnerving. In summary, spoilers don’t generate downforce so much as prevent aerodynamic lift.
Wings, on the other hand, like on the Daytona and Superbird make downforce. Like an airplane wing turned upside down, they are designed to create downforce with minimal drag. They are usually found on race cars, few production models have true wings, they have to be fairly large to have much effect.
And finally there’s ground effects that Rogue Leader refers to. In the late 60’s Colin Chapman was the first to utilize the idea of a smooth bottom car with a couple venturi tunnels. The venturi tunnels created a low pressure zone beneath the car, in effect, sucking it to the road with no increase in drag.
Giff
Old Feb 19, 2004 | 11:35 AM
  #33
roadkillZ28's Avatar
thats great ! thanks a lot
CARiD
Feb 9, 2015 09:35 AM
Alien
West South Central
Jan 11, 2015 12:51 PM
Jul 4, 2005 05:00 PM
RedLineRev
Jan 23, 2003 03:51 PM
NED4SPD
Sep 16, 2002 10:45 PM
