Wierd Noise ... Need advice
I have a 01 SS stock ls1 with headers back exhaust. Went on vacation this weekend and while I was gone it started making a wierd noise comming from the driver side closer to the firewall. The noise is hard to describe it kind of sounds like a belt squeak with a light ping. While accelerating you can hear it but once you get to a cruising speed it no longer does it. What could this be? Thanks for any advice.
Wierd Noise
I know its not a exhaust leak I have already checked that. It almost sounds like a bird chirping belt squeak bad gas ping all together I know your laughing but not sure how else to describe it. Any other thoughts would be greatly appreciated.
I would stick with premium too.Thought I was ok with mid-grade cause I don't usually get on it too hard but the ping showed up on a steep hill.Could also be the belt squeeking as well.Mine did that so I replaced it with a Goodyear gatorback & it went away
never again.
