weird sound
Old Mar 2, 2004 | 10:08 AM
z28spd's Avatar
Question weird sound
when i turn and accelerate at about 25mph+ a turn and sometimes slower it sounds like something is about to rip out from under the car or like its binding under pressure. Anyone know what the prob could be?
Old Mar 2, 2004 | 04:57 PM
SpeedzAdisease's Avatar
Mine does the same thing ?????
Old Mar 4, 2004 | 06:57 AM
z28spd's Avatar
anyone got anything to say?
Old Mar 4, 2004 | 12:38 PM
teke184's Avatar
where?
front, back, left, right?
that may help...
jack it up an tighten every suspension part you can think of...and check your bushings
Old Mar 4, 2004 | 01:30 PM
Mine comes from the rear of the car !
Old Mar 4, 2004 | 02:12 PM
teke184's Avatar
from the rear when turning....if it's not any of the bolts for the phb or lca...
probably your posi is shot...not all that uncommon from what i've noticed.
Old Mar 5, 2004 | 12:16 AM
savage99ss's Avatar
mine was doing the same thing.....i had to replace my bushings in the rearend...
Old Mar 5, 2004 | 08:59 AM
How would I go about checking the bushings in the rear end ??? Damn GM crap !!!!! I love my car but I miss the rag out but not destroy everything in the process Honda.
Old Mar 5, 2004 | 09:56 AM
teke184's Avatar
i think he's refering to the panhard bar and lower control arm bushings...they are soft rubber and can deteriorate
possibly the torque arm or trans mount too...
i'd put a beer on it being in the LSD...have the fluid changed and make sure they add the LSD additive...could be a cheap remedy
Old Mar 5, 2004 | 11:28 AM
Nittanymarine's Avatar
i would check the LSD as well. From working at a GM dealer, ive seen that be a minor problem. Its always a good idea to make sure everything is tight nder there, as far as bushings go too. If you got your differential serviced recently, make sure that the additive was added too. Good luck with your dilemna.
Old Mar 7, 2004 | 11:36 AM
adam_3's Avatar
My car does that too. I had a friend of mine look at it and he said that if was the limited slip making all the noise. He said that if the wrong kind of fluid gets put in them they pop and grind. He told me to put full sythetic in it and it will go away. Either that or regular with the lSD additive, but that will only last for so long then you will have to put it in again.
Nayr
Mar 3, 2023 08:34 PM
94Maroz28
Oct 27, 2015 04:38 PM
PopoFormula
Oct 12, 2015 04:19 PM
4586
Sep 27, 2015 01:55 PM
Ryan Ramsaran
Sep 19, 2015 08:43 PM
