Anyone here convert their Lt1 to a LS1?
Trust me with the mods done to my car, its a LOT cheaper to convert over
Where am I gonna find a 3400lb LS1 with a moser 12 bolt and full rear suspension package for less than a motor swap?
It can be done.. I have 2 buddies that have done this.. The entire wiring of the car has to be changed over to the LS1 style.. interior and exterior (of course). Everything else that has to do with a lt1 on the front end has to go.. K-member, radiator, etc.
I've found that you still have to use the LT1 style for the air induction. Still have you use to bellow and the same spot for the air intake.
They both work for an fbody shop here in Cleveland so the parts came very easy and cheap for them to do it.
I think one of the guys SN on here is SS350S10 or formulized94.. Don't think he'll mind a question or two.
Originally posted by S. Holley
NOt sure but there may be some issues with hood and fenders...
You only need to get a different hood if you plan to use the factory LS1 air box.. Other than that, you do not need to change your hood to fit an LS1 under your stock LT1 hood..
I've seen 2 of them w/o a different hood and a LS1 underneath it..
Jul 4, 2005 05:00 PM
smacz28
Aug 6, 2002 01:51 PM
