weird button thing
Old Dec 25, 2003 | 12:59 AM
tombodad's Avatar
weird button thing
hey guys
In my ashtray on my 98 z28 (i think the ashtray is the thing right behind the shifter) theres a strange button mounted in the corner. it has a yellow and a green wire running from it toward the front of the car--Anyone know what this is or was? thanks
Old Dec 25, 2003 | 01:21 AM
99blackSS's Avatar
It's not stock. Maybe it was for nitrous. Another common thing would be an electric cutout or neon lights. I'd follow the wires.
Old Dec 25, 2003 | 01:26 AM
tombodad's Avatar
ya thaats what i was gonna do.
Old Dec 25, 2003 | 03:38 AM
cerealtool228's Avatar
toward the front? Line Lock? Elec Fan?
Old Dec 25, 2003 | 11:33 AM
teke184's Avatar
if it's an auto isn't there a mod to switch to "performance shift" mode?
Old Dec 25, 2003 | 04:31 PM
RS Dragster's Avatar
Kind of. It's actually a little box with a switch. I guess it could be re-wired to a button though
Old Dec 25, 2003 | 04:46 PM
PDCamaro318's Avatar
where is box with the switch in it? i have never noticed it in my car.
Old Dec 25, 2003 | 08:11 PM
Sorry, should have been more clear: the button talked about above (with the box) is actually a mod you can get that plugs into your tranny, then you run the box into you compartment, and you can change the firmness on the go. But yeah, there isn't one from the factory. Sorry, my bad.
Old Dec 25, 2003 | 09:41 PM
dont worry bout it RS i just needed a lil clarification.....so how would i go about making the "performance shift" button for my interior...like what would i need to do?
Old Dec 26, 2003 | 11:44 AM
Well, IMO I don't know why you wouldn't firm shifts ALL the time. Softer shifts actually slip the tranny and cause more wear and tear than harder shifts would.
BUT, if you do want to do a swith, the only way I'd know is to get that tranny module. I think SLP is the one that makes it. Like I said, it's plugged into your tranny, then you run it up through the bottom of the car, through the shifter, I think. Then you could either use the box they supply or have a friend who knows wiring, and wire up your own button/switch.
Hope this helps
Old Dec 27, 2003 | 12:40 AM
tombodad's Avatar
I figured out that the button is actually not a button, bhut a light. anyone have any ideas what this was for? it doesnt light up....
Old Dec 27, 2003 | 02:25 AM
camaro322hp's Avatar
there is an ashtray light that comes stock in our cars. turns on when interior lights are on. i guess it's to see while you're counting your change in the dark...
DirtyDaveW
Dec 1, 2016 05:37 PM
97z28k&N
Jan 9, 2015 04:58 AM
tds1213
Nov 27, 2014 12:55 PM
Hal Fisher
Sep 14, 2002 09:36 PM
AW/whiteZ-28
Sep 1, 2002 08:16 PM
