Have I destroyed my suspension?
Old Dec 26, 2003 | 11:54 PM
LS1-Maniac's Avatar
I was installing my new Flowmaster Cat-Back tonight and when I set the car down off the jack it looks like it's pinched the over the axle pipe between whatever that suspension piece is (goes from one end of the axle to the other) and the trunk along with the metal heat shield. That suspension piece looks like it's bent around the pipe and the pipe looks squished a little bit. I haven't taken a real close look but I think it's probably pretty messed up. Have I totally screwed up my car?
Old Dec 27, 2003 | 12:19 AM
KamaroL98's Avatar
it dosent sound like nothing major, but i have to see what your talking about thats bent, mabey i gather its the sway bar, or panhard rod. Eitherway, they are both easy and cheap to replace.
Old Dec 27, 2003 | 12:26 AM
LS1-Maniac's Avatar
I'll try to get a picture of it with my digicam tomorrow when there's light. It's the thing above the axle that looks like a sideways V. I've got the car back up on jack stands right now and I'm sort of afraid to set it back down for fear of further damaging my suspension.
Old Dec 27, 2003 | 12:42 AM
LS1-Maniac's Avatar
This is a picture I found on the internet. It's the two black bars that go across the rear-end only I just have the stock ones.
https://www.camaroz28.com/~chris/mmexhaust/pic00005.jpg
Old Dec 27, 2003 | 12:51 AM
My84Z's Avatar
i believe your talking about your panhard rod and if your car has the 1le suspension wich most firehawks do your car is alittle lower then most so by putting in a biger exhaust you lessen the room. so i would say your suspension is fine.
Old Dec 27, 2003 | 06:26 AM
KamaroL98's Avatar
Yea, you bent the panhard rod. It keeps the rear end straight when moveing. So when you take off down the track and it looks like should be going left, but your going straight. Then its messed up. j/k. I dont know if that would happen, but they are cheap to buy, BMR makes a good one. Summit racing can probabily get one to your door the quickest. Lakewoods is good, and i have the red Hotchkis on mine. Since you will have it up again, go ahead and buy some Lower Control arms, they will help traction and are also cheap.
Old Dec 27, 2003 | 10:57 AM
DARK AGE 53's Avatar
It's kind of hard for me to tell which bar your talking about, is it the lower panhard bar or what some call the upper panhard bar? If it's the lower panhard you should replace it, the upper panhard can be modified to clear the exhaust. I can't remember were I saw a picture of the modified bar, what they did was cut out the section were the exhaust touched the panhard. They then fabed up a piece that went up and over the exhuast pipe and welded it into place. Sorry I couldn't explain it better.
Al
Old Dec 27, 2003 | 11:07 AM
SteveC's Avatar
From: Poway CA, where GOD and the sun always shines
Smile
I believe you are talking about the "Upper Panhard Bar" which has a bend in it anyway. Check out the picture on the right:
http://www.granatellimotorsports.com/gmpanhardrods.htm
SteveC
Formula Steve
Sep 19, 2023 08:31 AM
RUENUF
Mar 13, 2016 03:37 PM
football4life
Oct 4, 2015 07:48 AM
97blackformula
Aug 27, 2015 06:02 PM
force10
Jul 30, 2015 04:56 PM
