Tempramental LS1s
Old May 31, 2006 | 12:01 PM
  #31
RussStang's Avatar
Re: Tempramental LS1s
Originally Posted by AL SS590 M6
TM holds all late model A4 cars back some and yes it's by softening up the shifts. You can easily gain ET by having it removed but it's at your own risk as it could, and I mean could not will, cause premature failure of your trans.
On most newer GM, torque management exists on the manual cars as well. Also, unfortunately with the manuals, since GM has moved to electronic throttles, everytime the driver shifts the throttle plate closes, despite whether he has his foot on the gas or not.
Old May 31, 2006 | 12:16 PM
  #32
BradcTA's Avatar
Get a tune from pcmforless.com or madz28.com.
Old May 31, 2006 | 08:43 PM
  #33
GhostZ28's Avatar
go to madz28 I hear he's the man at mail orders
Old Jun 1, 2006 | 10:28 AM
  #34
darrens99formul's Avatar
Originally Posted by SFB767
I've heard that Torque Management is what holds the new GTO back from running exactly with LS1 F-Bodies. Is this true?
Torque management, IRS and the extra weight are all working together to hold the new GTO's back a little at the track. But then again, they were not meant to be straight line muscle. They are meant to be a comfortable sedan with a lot of attitude. Mission accomplished IMO.
I've also heard that TM makes the tranny last longer because it deadends the shifts a little bit.
Torque Management definately prolongs the life of the transmission. But TM also holds back the performance at the track. You have to decide what's most important to you, easier on the tranny or faster at the track. Anyone who drag races regularly will make this choice easily. My TM has been deleted for almost a year now
I think my car may be running a little rich because the exhaust fumes are stronger with the headers on.
LT headers (even with HF cats) will cause the exhaust fumes to smell more. That's completely normal and by itself not a symtom of anything. But it's also very common for a LS1 to run a little lean or a little rich after LT headers. A good tuner can take care of this however and open up some power.
So do you think a professional dyno tune is the definite answer?
I do. Because no matter what it'll be worth the time and money spent. Even a bone stock car can pick up a few ponies from a dyno tune. I put in my converter, LT headers and ORY. My car was running badly lean and I was way down on power (trapping 103). The dyno tune I had done corrected my AFR, allowed for some other minor tweaking and I ended up finding 29 missing rwhp. After the tune I was trapping 107-110 and I went from 13.3 to 12.5 in ET.
But even if you only find 10 rwhp your that much faster, have current dyno numbers for your sig and will probably have a much better idea of what might be holding you back (if anything).
Good luck.
13qtr
Oct 28, 2016 08:11 PM
Ericksd
Jan 20, 2016 06:07 PM
Hal Fisher
Sep 30, 2015 09:03 PM
Z Power
Sep 19, 2015 11:19 PM
1slow93z28
Sep 1, 2015 06:22 PM
