Tempramental LS1s
Re: Tempramental LS1s
Originally Posted by 1stls1
Also, what track were you at? Moroso REALLY sucks for hookup!
Stock I would spin 1st-2nd gear, auto! I dont know if I missed it but are you auto or stick?
Stock I would spin 1st-2nd gear, auto! I dont know if I missed it but are you auto or stick?He gave his 60' so that it a mute point.
Well best of luck to you man. I hope you get it figured out, and the problem nailed. it makes me scared of mine. I've actually never ran at the track before... i dont wanna bomb at 13.5+
Track experience means a lot...
I'm sure guys that cracked below 13s stock weren't first timers or even newbies for that matter.
You can have an awesome car - but it takes a lot of practice to learn it and do well in the 1/4mi...
I'm going to run it a few times as it is now, but in about 2 months i should be pushing near 420ish rwhp. I'm going to have to go very easy on the launch as to not send my diff out the back, but I'm expecting maybe low 12's with a good trap. what do you guys think?
Was it indeed a 30th anniversary t/a? that expalins it all thats about right for the LT1 convertable to run high 13's moded lightly. Ive got A 35TH ss and my buddy has a 35th trans Am. his car runs 13.4 and mine is 13.08 some ls1 are faster than others. We were both stock at time @NED (local strip) i mean his was supposed to have a little less curb wieght too. ive seen some LS1's that run 14 second passes all day long. And others that the driver just cant shift the thing but you both had auto's as did we. Sometimes too we make changes to our cars and they seem to have go back the other way reactions performance wise, so to speak. Like the old saying goes dont do too many changes at once or else you wont know what to undo. That may be my case with this new convertor i ran 13.08's last year completely stock. Add a convertor and drag radials and i become slower. This could have something to do with this guys case in the 30th or 35th edition t/a.
Tempramental LS1's indeed!
'99 Trans Am 30th edition? but thats two years after the '97! Then why was the 35th's were in 2002 why would the 30th t/a be in 99 that doesnt make any sense at all. Sorry just aint computing is all.
Originally Posted by SFB767
I have a questions about two LS1s: Mine and a guy's at the track Thrusday night.
The best time ever with my car is in my sig. Why do I keep hearing that bolt-on LS1s will easily go into the 12s? I'm cutting 2.1 and 2.0 60' times. Could my transmission be holding me back? I have a cooler on it too. I thought I'd at least run around a 13.1@107 with my mods.
Your car does seem to be a tad underpowered IF the dyno numbers in your sig was with all the current mods. I would expect your car to pull closer to 320 rwhp with a lid, catback and LT's. You may be running a little rich or a little lean in the A/F ratio. I would suggest you get a stall, drag radials and then a good dyno tune. I bet you run mid 12's all day long after that (see my sig).
There was a guy with a 30th Ann. T/A convertible behind me with a Hooker catback, lid, tuning, 3.73s, and a 2800 converter on BFG DRs and was running high 13s at just a hair over 100 MPH. Were his gears not matched to his converter? I kind of felt sorry for him after dropping all that cash into his car and running like a stock LS1. He was cutting 1.9-2.0 60' times too. What was wrong with this guy's car?
Actually looking at your sig .. all you realy have is lid, catted LTs and an exhaust ... given your 60's and depending track conditons, your times are in the ballpark.
As for the T/A ... too many unknowns. Maybe the guy just can't drive or whoever tuned his car really screwed the pooch.
Originally Posted by AL SS590 M6
Both of these cars need tunes to remove TM, adjust shift points, and get the AFR right and they'd run a LOT better.
I've also heard that TM makes the tranny last longer because it deadends the shifts a little bit.
I think my car may be running a little rich because the exhaust fumes are stronger with the headers on.
So do you think a professional dyno tune is the definite answer?
Firebird's were Commerative Editions (hence they are known as CETA's)
Camaros and Firebirds came out the same year (1967) but Pontiac doesn't celebrate the birth of the Firebird. It only celebrates the birth of the Trans Am which was in 1969.
So Camaro anniversary models are in years with 7s and 2s and Trans Am anniversary models are in years with 9s and 4s and there are no anniversary model Firebirds that I can remember.
I've heard that Torque Management is what holds the new GTO back from running exactly with LS1 F-Bodies. Is this true?
A dyno tune on a car with mods will always help, if the tuner knows what he's doing, but it's not majic and no one can guarantee that it's the definite answer to all your woes.
