TEmp gauge hitting 250F...
Old Jul 27, 2006 | 07:04 PM
  #31
blackrat's Avatar
Re: TEmp gauge hitting 250F...
Ah, here it is. THis is the thread with the ducting I was talking about.
http://web.camaross.com/forums/showt...44#post3959144
Old Jul 28, 2006 | 08:04 PM
  #32
touch109's Avatar
do u have pics of the installation..
Old Jul 31, 2006 | 06:09 PM
  #33
danziger's Avatar
I just had this same problem. Car always runs at normal temps locally, but I took her on a 500+ mile round trip and had the same symptoms you described on the way back. I also changed my coolant about a year ago. Here's what I came up with:
When the gauge was reading 250+ and I parked, the engine still didn't seem overly hot. The fan only stayed on a minute or so after parking and the upper radiator hose was hot, but not ridiculously so. I noticed bubbles in the radiator water when I restarted and was able to add 2 16oz bottles of water. I turned the heater on full blast then the A/C then the heater and the coolant plummeted, so I added more water. Conclusion? I think there was a bunch of trapped air in the coolant system. Try bleeding yours out real well and see if it helps. Ben
Old Jul 31, 2006 | 06:22 PM
  #34
Klypto's Avatar
Originally Posted by touch109
The speed i was traveling was around 65-85 with no traffic... I do hava a body kit. xenon just put on about 1 month ago.. When i travel local the temp gauge stays around 200-210... The trip i took was about 50 miles long, on the way there the temp was high and on the way back it was the same, i did notice when i turned the a/c it got hotter.. but never to the point were it was hitting red, but close....
****. mine over heats too hwy, and i have a xenon body kit... came with it from previous owner.... anyone else have input on this?
seems to only happen to me when its hot as hell outside...
cory
Old Aug 1, 2006 | 11:33 PM
  #35
blackrat's Avatar
cory
Well, like I pointed out earlier, take a look dead on at your air dam. You can see that the lip is blocking a good portion of the dam. An SSRA will only exacerbate the problem. I'm not aerodynamics expert but I could imagine at high speeds the dam will be getting very little direct air because most of it will be diverted. Not much you can do other then get a bigger dam, ditch the lip, or run some ducting like I'm going to do.
Sorry, I don't have pics as I haven't done it yet, currently dealing with having to install an adjustable master cyliner, so first things first.
Old Aug 1, 2006 | 11:47 PM
  #36
touch109's Avatar
what about the slp radiator, 160 gauge, and fan control. Might this help in keeping the temp down... would i need anything else like the slp oil pump.. The funny thing is i spoke to xenon and they told me they had never any complaints about the kit i was the 1st one....
Old Aug 2, 2006 | 09:11 AM
  #37
blackrat's Avatar
Your Car is mostly stock. your cooling system should be more than capable of handling it. buying all that is just trying to cover up the problem instead of fixing it.
Old Aug 2, 2006 | 03:24 PM
  #38
Klypto's Avatar
but fixing it could been removing the body kit, which if that is it, i wont be fixing it, but going "around" it... (at first i was like, eh, the body kit is alright, but after having it for so long... the car looks naked without it...
cory
Old Aug 2, 2006 | 08:43 PM
  #39
touch109's Avatar
Should we just tell xenon that we are having problems with their body kit... when i told them they didnt know there was a problem.. if enough people tell them they might help us put with something...
Old Aug 2, 2006 | 08:52 PM
  #40
blackrat's Avatar
cory
No, you shouldn't have to remove your kit, I know I'm not removing my front lip. All I was reffering to is that buying all that stuff might be uneccessary, if not worthless, if all that is needed is more airflow to your radiator. That would mean having to do something creative witht he dam (like lowering it or making a larger one) or creating ductwork to get more air there.
Old Aug 7, 2006 | 11:10 AM
  #41
touch109's Avatar
another thing that i noticed is that my driving around for a period of time over 30 min an having the a/c all that time on... it gets to a point that it doenst blow out almost any air, and it could be on the max setting .... but the car temp stayed around 210... what can i do to fix this
Biggiebound
Apr 23, 2015 08:50 AM
Biggiebound
Apr 21, 2015 11:28 PM
cmdeshon
Dec 27, 2014 10:06 AM
brentbrowning01
Dec 16, 2014 06:35 AM
ro2207
Dec 4, 2014 06:18 PM
