TEmp gauge hitting 250F...
Old Jul 23, 2006 | 12:25 PM
  #16
touch109's Avatar
Re: TEmp gauge hitting 250F...
The speed i was traveling was around 65-85 with no traffic... I do hava a body kit. xenon just put on about 1 month ago.. When i travel local the temp gauge stays around 200-210... The trip i took was about 50 miles long, on the way there the temp was high and on the way back it was the same, i did notice when i turned the a/c it got hotter.. but never to the point were it was hitting red, but close....
Old Jul 23, 2006 | 12:54 PM
  #17
Greed4Speed's Avatar
Check your system pressure.
Old Jul 24, 2006 | 07:55 AM
  #18
AL SS590 M6's Avatar
Moderator
As stated above make sure that your plastic air dam is still there. It should be attached to the radiator support to deflect air up and thru the radiator.
Old Jul 24, 2006 | 08:40 AM
  #19
01Z's Avatar
01Z
I'll bet that's it; 2+2 and the other facts known, it's has to be either a missing air dam, air foil panel in front of the radiator or some front spoiler radically redirecting the air flow. Please let us know what you find....
Here's what I mean by the airfoil panel (pulled up & out .. and no, this isn't my car....
Old Jul 24, 2006 | 09:27 AM
  #20
touch109's Avatar
it is still there but its connected to the orginal bumper. the xenon bumper has nothing connected to it. its about a 4in differnce between the orginal bumper and the xenon front dam
Old Jul 24, 2006 | 09:57 AM
  #21
GoFast908Z's Avatar
Member
How was your AC running at those temps??????
mine shuts off at 230*
WTF
Old Jul 24, 2006 | 10:10 AM
  #22
touch109's Avatar
the a/c was working just fine even when the gauge reached 240..
Old Jul 24, 2006 | 10:18 AM
  #23
01Z's Avatar
01Z
I'd like to see the car with the body kit. If you can post it up it might make sense of what is happening with the air flow. Also, from your post above, I'm wondering if the reading you are seeing is accurate. With temps at 250 degrees, I would think you would begin to feel the heat just being in the vacinity of the engine compartment.
Old Jul 24, 2006 | 10:22 AM
  #24
touch109's Avatar
just go to the link below and you can see the car.. and the day this happend it was really hot arounf the engine.. i opened the hood let it cool in the garage.. when i came back about an hour later it was hotter in the garage that outside.. the temp outside was 96 ..
Old Jul 24, 2006 | 11:47 AM
  #25
SSpdDmon's Avatar
I'd say (once you get up to speed) you've probably lost at least 20% of the airflow to the radiator you would have normally had without that body kit. Even still, there has to be something else contributing. I have an SSRA that sits right in front of my radiator shroud and I don't see ECT's above 225* on a 96* day. I'd get under there and see how it looks...see if you can see any obstructions or loose pieces that might get in the way of airflow.
Also, according to EFILive, above 65mph both fans will shut off "unless above engine coolant temperature turn on thresholds." This means that if your above 65mph, fan one and two will shut off if your ECT is less than 226* (fan one's turn-on temp). Fan two's turn-on temp is 233*. So, even if you're going 80mph, the fans should turn on if your ECT's get that high. That's why it's odd that it only was doing it on the highway...unless the turbulance stream coming off of the new bumper is redirecting more than 50% of the normal airflow you would have seen.
Old Jul 26, 2006 | 11:56 PM
  #26
touch109's Avatar
this time i went about 100 miles traveling around 65-75 miles per hour but there was some traffic and had the a/c off... but i did notice on the temp gauge it did go up a bit to about 215-220... if it is the new xenon bumper what can i do about it and had anyone else had that problem with the xenon bumper..
Old Jul 27, 2006 | 12:17 AM
  #27
01Z's Avatar
01Z
If you don't mind some rambling thoughts, I would think about extending the air dam down a little. Even 1/2" might make all the difference. I also would contact the kit manufacturer or at least the people who installed the kit. They might have a solution because if you are having the problem, you can figure someone else is too.
Old Jul 27, 2006 | 10:20 AM
  #28
blackrat's Avatar
ive put up a few similiar posts about my overheating. i too have a gfx kit with a front lip, plus an ssra. i would get bad overheating issues while pushing the engine at high speeds, even with fresh coolant, wetter, and 160 stat and fan setting. looking at it from the front i could see that i was blocking a large amount of the dam. ive bought some ducting to help flow more air to the rad and am also going to get a bigger dam. loom under my previous posts about a month ago and you can see my thread and solution ideas.
Old Jul 27, 2006 | 11:52 AM
  #29
touch109's Avatar
i looked at your previos reponse but didnt see how to fix it wat this it.. http://web.camaross.com/forums/showt...ht=overheating
Old Jul 27, 2006 | 12:40 PM
  #30
blackrat's Avatar
cant View that page because im doing this over my phone right now, but if its the one where i put up pics of some ducting then yeah, thats the one. i cant think of any other way to get more air there without getting rid of the lip. you might be able to shim the stock air dam, that might be worth a shot but then you would have clearance issues.
