TEmp gauge hitting 250F...
Re: TEmp gauge hitting 250F...
Ah, here it is. THis is the thread with the ducting I was talking about.
http://web.camaross.com/forums/showt...44#post3959144
I just had this same problem. Car always runs at normal temps locally, but I took her on a 500+ mile round trip and had the same symptoms you described on the way back. I also changed my coolant about a year ago. Here's what I came up with:
When the gauge was reading 250+ and I parked, the engine still didn't seem overly hot. The fan only stayed on a minute or so after parking and the upper radiator hose was hot, but not ridiculously so. I noticed bubbles in the radiator water when I restarted and was able to add 2 16oz bottles of water. I turned the heater on full blast then the A/C then the heater and the coolant plummeted, so I added more water. Conclusion? I think there was a bunch of trapped air in the coolant system. Try bleeding yours out real well and see if it helps. Ben
Originally Posted by touch109
The speed i was traveling was around 65-85 with no traffic... I do hava a body kit. xenon just put on about 1 month ago.. When i travel local the temp gauge stays around 200-210... The trip i took was about 50 miles long, on the way there the temp was high and on the way back it was the same, i did notice when i turned the a/c it got hotter.. but never to the point were it was hitting red, but close....
****. mine over heats too hwy, and i have a xenon body kit... came with it from previous owner.... anyone else have input on this?
seems to only happen to me when its hot as hell outside...
cory
cory
cory
Sorry, I don't have pics as I haven't done it yet, currently dealing with having to install an adjustable master cyliner, so first things first.
what about the slp radiator, 160 gauge, and fan control. Might this help in keeping the temp down... would i need anything else like the slp oil pump.. The funny thing is i spoke to xenon and they told me they had never any complaints about the kit i was the 1st one....
Originally Posted by blackrat
Your Car is mostly stock. your cooling system should be more than capable of handling it. buying all that is just trying to cover up the problem instead of fixing it.
cory
Should we just tell xenon that we are having problems with their body kit... when i told them they didnt know there was a problem.. if enough people tell them they might help us put with something...
but fixing it could been removing the body kit, which if that is it, i wont be fixing it, but going "around" it... (at first i was like, eh, the body kit is alright, but after having it for so long... the car looks naked without it...
cory
cory
another thing that i noticed is that my driving around for a period of time over 30 min an having the a/c all that time on... it gets to a point that it doenst blow out almost any air, and it could be on the max setting .... but the car temp stayed around 210... what can i do to fix this
ro2207
Dec 4, 2014 06:18 PM
