tach output for shift light?
Old Jul 11, 2003 | 07:51 PM
teke184's Avatar
ok guys ...having a bit of trouble installing my proform shift light
i thought i read tthat the tach output was red connector on ecm, pin 10, white wire. well i've tried this and it's not working
so i do anohter search and i get this thread saying blue connector, pin 35.
what is the correct wire to spice into?
i already have the wire run up through the firewall to the ECM so i don't want to mess with pulling the bottom of the dash apart...so i'm gonna connect it at the ecm so don't bother telling me which wires under the steering wheel or whaterver...
and also in that tread someone mentions needing to cut one of the wires on the shift light as if it were a 4 cylinder due to the strange ignition of the LS1...
is this true???
Old Jul 11, 2003 | 08:03 PM
LBJ's Avatar
LBJ
Red connector #10 pin (white) is the one I used. Iam using the autometer shift light.....I had the same problem when I hooked mine up. The problem was the connector I was using to connect the shift light wire and #10 wire together. The #10 wire is small and I didn't have a good connection!
Good Luck
Old Jul 11, 2003 | 08:23 PM
teke184's Avatar
i read some stuff on LS1tech.com about the same problem having to put the light into 4cyl mode.
i have a PROFORM shift light...there are two wires that are for 6 or 4 cyl mode...which do i cut ...or both?
Old Jul 11, 2003 | 08:37 PM
LBJ's Avatar
LBJ
Come on guys....someone else has to have a proform set up....help the guy out!
Old Jul 12, 2003 | 03:37 PM
teke184's Avatar
yeah...please help me...
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
ldtantlinger92
Jan 19, 2015 01:26 PM
GigaMp3z
Feb 20, 2003 02:57 PM
Brady
Jul 29, 2002 10:30 PM
