Strange Engine Noise(Vid inside)
Old Mar 8, 2006 | 01:40 PM
lil_mikey69's Avatar
Well, yesterday I noticed a strange whisteling noise coming from the engine compartment while I was dropping some stuff off at the mail box. It sounds like something is leaking 'compressed air'. There is a steady noise while the engine is running. Also after turning the car off it goes on for a second, and then you can hear it release the pressure I made this video in hopes that someone would maybe recognize the problem? The car seems to be running normal, and all gauges seem to be at proper levels. Any ideas would be very helpful.
You may have to right click save as: Idle + Shut Down
Old Mar 8, 2006 | 02:04 PM
njenson's Avatar
Re: Strange Engine Noise(Vid inside)
that is quite odd
Old Mar 8, 2006 | 02:07 PM
SUTTERERMAN85's Avatar
check the rubber gromet that connects to the intake right behind the TB. its where the pcv vavle tube goes into the intake on the pass. side. i fixed that on an ls1 before the rubber part was craked on the back side where you cant see it.
Old Mar 8, 2006 | 04:00 PM
I'll try and check that.
Just to let everyone know, there hasn't been anything done to the car recently, it just started. Not like I had the intake off last week or anything like that. I mean it's getting up there in age I suppose, and has 75k miles so I expect things to fail...I just can't figure out WTF this is. I didn't see anything apparent when I checked. Maybe my dad will be able to offer some assistance.
Old Mar 8, 2006 | 06:23 PM
Rods99Z's Avatar
I had that same noise and it was the rubber hose that connect to the intake like suttererman85 described above.
Old Mar 8, 2006 | 08:08 PM
yep they get real dry rotted and tear out of the middle of no where
Old Mar 8, 2006 | 08:51 PM
Is this a fairly easy repair? I can't imagne the part cost very much, does it? Can it be picked up at a local autoparts place?
Old Mar 8, 2006 | 08:53 PM
prob have to go to the dealer or get a piece of hose that will fit well. that would be the cheap fix and what i would do.
Old Mar 10, 2006 | 12:52 AM
Either of you guys have any idea what it is called, if it even has a specific name?
Old Mar 10, 2006 | 09:11 AM
no its just a piece of rubber tube that connects the PCV valve to the intake where it hooks onto the intake
Old Mar 10, 2006 | 02:46 PM
Firehawk0194's Avatar
I went down to the part store and had them cut me off a hose about 3.5" long that was the right diameter. The dealership will want you to guy the whole unit that is like 90 bucks when all you need is the hose. Try to find the size of the hose you need and make it yourself. Much cheaper!
Old Mar 11, 2006 | 02:29 AM
I ordered just the hose from the dealer for $25. While I may have been able to do it cheaper, I felt that was reasonable enough.
Old Mar 12, 2006 | 06:42 PM
Found the culprit.
It was $2.00 to replace.
Old Mar 27, 2006 | 12:10 PM
damn i am good... Lol glad you got her fixed up.
nick
Fatdog2
Feb 12, 2015 12:24 PM
squarehead
Nov 21, 2014 08:02 PM
StngStlkr
Sep 6, 2002 05:47 PM
Omega9
Aug 2, 2002 12:33 AM
