Starting Problems
Old Feb 13, 2012 | 02:44 PM
aggieguy13's Avatar
Starting Problems
battery is a week old. (thought that was initial problem so i replaced it) but the car is not wanting to start only 73k miles. the battery gauge isnt too terribly low it ends up like 1-2 needle widths past the redline when i try to start it. i tried pulling the radio fuses and if it is only setting for a few hours then it will start if i do this, but if it is going to sit over night this doesnt even work. but at any time if u jump it off. it will fire right up. any ideas?
Old Feb 14, 2012 | 02:01 PM
Marc 85Z28's Avatar
Re: Starting Problems
Forget about the voltmeter in the instrument panel, it's useless.
You need to perform a battery draw test - do a Google search.
Old Feb 14, 2012 | 09:57 PM
aggieguy13's Avatar
i was at autozone and had the battery/starter/alt. tested today. all checked out good.
Old Feb 15, 2012 | 07:43 AM
Marc 85Z28's Avatar
No. You need to perform a battery draw test. Google it.
Old Feb 15, 2012 | 02:53 PM
aggieguy13's Avatar
ya i just read too fast. i gotta get a meter
Old Feb 16, 2012 | 05:35 AM
Marc 85Z28's Avatar
Or you could just rig up a test light with a 12 ohm bulb.
Alex Barnes
Jan 24, 2015 10:21 PM
Oncomingstorm22
Jan 22, 2015 07:15 PM
HCz28
Jan 11, 2015 11:21 AM
97z28k&N
Jan 9, 2015 04:58 AM
97SSdude
Dec 31, 2014 07:43 PM
