Stage 2 heads
It really depends on which ones you get. I've been told that you would usually buy a camshaft to match your heads. In this case you'll need to select the right set of heads for your camshaft. You might get the 5.3 heads for more compression over the 5.7 heads. I would get with your cam manufacturer and ask what heads they recommend as a match for their cam. Then check with head suppliers to make sure they say their heads are optimal for your cam.
importkiller94
Jan 17, 2015 09:03 PM
1LEThumper
Jul 14, 2003 12:45 PM
Black Sunshine/ 00SS
Jul 17, 2002 08:41 PM
