Rearend not center
Old Aug 15, 2003 | 02:13 AM
dist0rtion_69's Avatar
Rearend not center
My strange 12 bolt rear isn't center. I have an adjustable torque arm, and adjustable panhard rod bar. The rear sits about 2 inches towards the right.. Which is enough to make the wheel/tire combo I just put on look awkward on the side that sits further in. What is the "proper" procedure to solving this. I'd rather not just try and screw with it at random.
Thanks!
Old Aug 15, 2003 | 08:00 AM
2002Z28SSConv's Avatar
You can get pretty close by measuring from the front of one control arm to the rear of the other control arm. Do the same on the other side. Adjust the PHB until the measurements are the same.
You can also just adjust it until the tires stick out the same distance on both sides.
Or take it in for an alignment. It will probably need one anyway. But if you just want to get by for a couple weeks it should do the job.
LT14LIFE
Nov 15, 2015 06:22 PM
WobblySausage
Oct 7, 2015 02:44 PM
WobblySausage
Oct 7, 2015 10:09 AM
Daluchman1974
Sep 11, 2015 06:12 AM
RX Speed Works
Aug 20, 2015 03:40 PM
