SLP FloPack all what it says?
Old Nov 2, 2004 | 06:44 AM
  #31
teke184's Avatar
Re: SLP FloPack all what it says?
or not be a wussy man and drive a manual
j/k
i would think even the SLP cai would get in the way with the tranny cooler.
but as al said...there are ways around it. sooooo - quitcherbitchin
Old Nov 2, 2004 | 06:57 AM
  #32
Will_Die_Trying's Avatar
Teke184: I respect your post amount and you seem knowledgable, but on your comment about the smoother bellows don't sell it short. the hole concept of air flow requires smoothing the air flow in the engine. from the intake proting adn smoothing to head port widening and smoothing(intake and exhaust) to smoothly bent exhaust pipes(as opposed to pipes bent with the ripples/kinks in them, i believe they call this manderal bent pipes). the bellows don't add much, but probably add more than 1hp. i would say 2-4 hp. increasing are intake pressure help signifacantly and alittle goes a long, long way. hence ported throttle bodies and low boost S/C and turbos. Just my opinion.
Old Nov 2, 2004 | 06:59 AM
  #33
FRDnemesis's Avatar
ok I'm a new LS1 guy????? what is the SSRA? what brand & who sells it?
jeff
Old Nov 2, 2004 | 08:27 AM
  #34
teke184's Avatar
SSRA is the super sucker ram air system.
www.lmperformance.com sells it. awesome product. do a search
willdietrying
"the hole concept of air flow requires smoothing the air flow in the engine. from the intake proting adn smoothing to head port widening and smoothing(intake and exhaust) to smoothly bent exhaust pipes(as opposed to pipes bent with the ripples/kinks in them, i believe they call this manderal bent pipes). the bellows don't add much, but probably add more than 1hp. i would say 2-4 hp. increasing are intake pressure help signifacantly and alittle goes a long, long way. hence ported throttle bodies and low boost S/C and turbos. Just my opinion"
well nobody has showed any dyno proof that a ported tb does any thing for hp. and the idea with mandrel bends is that the "compression bent" exhaust pipes is that the final diameter in those bends is smaller on top of the fact that the kinks hinder flow.
and if a lid is only worth 7-8hp at the wheels...and looking at how much restriction the stock has....there is no way a few ripples in some plastic, that is wider than the other parts of the intake track...is going to get you 4hp!!
consideering the air has to flow through the small air inlet, up through the lid, through the MAF, over the TB blades, then get split up in the intake manifold...i can't imaging that minut amount of added turbulance from the bellow making a lick of difference.
but keep thinking you're getting 4hp from it
not to mention the number of complaints i've seen for lids cracking and not fitting correctly due to insufficient flex when the motor torques up and twists...i wouldn't buy it anyway.
Old Nov 2, 2004 | 08:34 AM
  #35
FRDnemesis's Avatar
[QUOTE=teke184]SSRA is the super sucker ram air system.
Thanks! I like the information on your web page. Some nice write-ups on parts!
Jeff
Old Nov 2, 2004 | 09:02 AM
  #36
jthomas's Avatar
Originally Posted by AL SS590 M6
Not if you want it bad enough. B&M makes a 19000 gvw rated cooler for street rods that is about 4 inches wide and 10 inches long. It fits very nicely alongside of the SSRA.
thanks for the info. is it a "plate" style cooler, or a tube 'n fin design?
Old Nov 2, 2004 | 09:06 AM
  #37
jthomas's Avatar
j/k
i was living in san francisco at the time i purchased the car. if it weren't for the horrible traffic in the bay area, i would have bought an m6 car.
Old Nov 2, 2004 | 09:58 AM
  #38
teke184's Avatar
FRDnemesis = jeff
teke184 = jeff
thanks for the compliment...i try to put helpfull info on it, not just a dozen pics from every angle.
san fran ...pffft
traffic...... pffft
wussy man
j/k
personally i like the leg cramps and the twitching muscles associated with traffic and a clutch
Old Nov 2, 2004 | 11:52 PM
  #39
jthomas's Avatar
san fran ...pffft
traffic...... pffft
wussy man
j/k
florida keys... pffft
no tortuous roads...pffft
f.u.
j/k
Old Nov 3, 2004 | 12:11 AM
  #40
AL SS590 M6's Avatar
Moderator
plate
G-BODYT56
Jan 14, 2022 11:14 PM
n2oblkz
Oct 12, 2015 01:53 AM
sahlomonic
Parts Wanted
Sep 22, 2015 03:13 PM
tommalcolm
Sep 11, 2015 03:39 PM
rideordie
Sep 7, 2015 08:22 AM
