RPO codes???
Old Sep 24, 2003 | 10:55 PM
Knowklew's Avatar
RPO codes???
Are the RPO codes for 1999 and 2000 the same? anyone have a link?
Old Sep 25, 2003 | 02:04 AM
chuck's Avatar
No link, but I saved these:
1999
A26 Window Glazing, European
AG1 Driver Front Seat, Power Adjuster
AH3 Front Seat, Manual 4-Way Adjuster
AK5 Inflatable Restraint System, Driver and Passenger
AN4 Restraint Provisions, Child
AQ9 Front Seat, Driver and Passenger Recline
AR9 Front Bucket Seat, Deluxe European Style
AU0 Remote Entry Lock Control
AU3 Side Door Elec Lock Control
AX4 Restraint Conversion Seat, Manual European
A31 Window, Power Operated Side
A90 Lock Control, Rear Compt Lid Remote Elec Release
B35 Covering Rear Floor Mats
B4C Sales Special Service Pkg (Police)
B84 Molding, B/S Exterior
CC1 Roof Hatch Removable Panels, Glass
C49 Rear Window Defogger, Electric
C60 HVAC System AC Man Controls
DD9 Mirror, O/S LH & RH Remote Control Electric Color
DE4 Sunshade, Removable Hatch Roof
DG7 Mirror, O/S LH & RH Remote Control Electric Color
D21 Sunshade, Windshield
D35 Mirror, O/S LH Remote Control, RH Manual Color
D82 Paint Special
FE2 Suspension System, Ride and Handling
FE4 Suspension System, Special Ride and Handling
FE7 Suspension System, Front and Rear Heavy Duty
FE9 Certification Emission-Federal
F41 Suspension System, Front and Rear Firm Ride and Handling
GU2 Axle Ratio 2.73
GU4 Axle Ratio 3.08
GU5 Axle Ratio 3.23
GU6 Axle Ratio 3.42
G80 Axle Positraction
IL2 Trim, Interior Leather (W/AQ9) Pontiac
IL4 Trim, Interior European Camaro
IL5 Trim, Interior (w/AQ9) Pontiac
IPB Trim, Interior Cloth Camaro and Firebird
IPD Trim, Interior (w/AR9) European Camaro
IP2 Trim, Interior Leather Camaro
IP3 Trim, Interior Leather Pontiac
JAF Brake Provisions, European
J65 Brake System, PWR Front and Rear Disc
K05 Heater, Engine Block
K29 Module Powertrain Control, Export
K34 Cruise Control, Automatic
K68 Generator, 105 Amp
LS1 Engine, Gas V8 5.7L SFI Aluminum
L36 Engine, Gas V6 3.8L MFI HO
M49 Transmission, Manual 5 Speed OD
MM6 Transmission, Manual 6 Speed OD
M30 Transmission, Auto 4 Speed Electronic
NK3 Steering Wheel, Sport Soft Rim Simulated Leather
NM8 Leaded Fuel System Compatible, European
NP5 Steering Wheel, Leather Wrapped
NP7 Steering Column, EEC Approved
NW9 Traction Control, Electronic
N36 Steering Wheel, 4 Spoke Sport
N60 Wheel, Aluminum Painted
N66 Wheel, Styled Aluminum 17" 5 Spoke Polished
N73 Wheel, Custom Sport Var4 17" (Restricted to Camaro SS)
N92 Cover, Wheel Bolt-on
N96 Wheel, 16 X 8 Cast Aluminum
N98 Wheel, 16 X 8 Cast Aluminum Chrome
PA6 Wheel, Styled Painted 16"
P05 Wheel, Styled Chrome 16"
QA9 Wheel, 17 X 9 Aluminum Painted (Blue Tint)
QB3 Wheel, 16 X 7.5 Steel
QCB Tire, All P235/55R16 BW
QEA Tire, All P215/60R16 BW
QFK Tire, All P275/40R17 BW
QFZ Tire, All P245/50R16 BW
QLC Tire, All P245/50R16 BW
TR7 Headlamps, Control Leveling System Automatic
T1G Vehicle, Military Personnel
T37 Lamp, Fog Deluxe
T39 Lamp, Turn Signal Aux
T43 Spoiler, Rear
T62 Lighting, Daytime Running Delete
T65 Lighting, Daytime Running Export
T78 Headlamp Control, Delete
T79 Lamp, Fog Rear
T82 Headlamp Control, Automatic ON-OFF
T84 Headlamps, RH Rule of Road
T85 Headlamps, LH Rule of the Road
T89 Lamp, Tail & Stop Export
T96 Lamp, Fog
UA6 Theft Deterrent System
UB3 Cluster, Inst Oil Cool Temp Volts Trip Odom Tach
UC2 Speedometer, Inst Kilo Positive Bias
UK3 Electronic System Steering Wheel Acc Controls
UL0 Radio, AM/FM Stereo Auto Rev Music Srch Cass Clock ETR
UM6 Radio, AM/FM Stereo Auto Rev Cass Clock ETR
UN0 Radio, AM/FM Stereo Compact Disc Auto Tone Clock
UQ0 Speaker Sys, 4 Dual Frt Dr Mtd Dual STD RGE Qtr/Shelf
UW3 Radio, AM/FM Stereo Auto Rev Music Search Cass Data Sys
UZ7 Speaker System, 8 Quat Frt Dr Mtd Dual RR Hatch Amplifier
U1S Player, Multiple Compact Disc
U62 Speaker System, 4 Dual Coax Frt Dual Coax PKG Shelf
U73 Antenna, Fixed Radio
U75 Antenna, Power Radio
VK3 License Plate, Front Mounting Pkg
VL4 License Plate, Rear Mounting Pkg
V12 Cooling System, Power Steering
V76 Hook, Tow
WS6 Performance Package Special
WS9 Model Conversion, Formula
WU6 Sales Package, Firehawk Upfitter
WU8 Sales Package, Z28 SS
W52 Entertainment System Option B
W53 Entertainment System Option C
W54 Entertainment System Option D
W55 Entertainment System Option E (MONSOON)
W59 Entertainment System Option I
W66 Merchandised Pkg, Formula
W68 Sales Package, Firebird Upfitter
W73 Entertainment System Option J
X10 Entertainment System, Option I
X20 Entertainment System, Option J
Y3F Sales Package, RS Camaro
Y81 Merchandised Pkg, Firebird
Y82 Merchandised Pkg, Trans Am
Y84 Merchandised Pkg, Trans Am GTA
Y87 Merchandised Pkg, Performance Enhancement
Z5X Mirror Provisions, Arabic Language
01U Primary Color, Exterior Special
1LE Performance Package, Component Special
1OI Interior Trim, Arctic White
10Q Molding Color, Arctic White
10T Top Color, Arctic White
10U Primary Color, Exterior Arctic White
11Q Molding Color, Pewter Metallic
11U Exterior Color, Pewter Metallic
102 Trim Combination, Leather Arctic White Camaro and Firebird
103 Trim Combination, Leather Arctic White Pontiac
105 Trim Combination, Leather Arctic White Pontiac
14B Trim Combination, Cloth Dark Gray
14D Trim Combination, Cloth Dark Gray
14I Interior Trim, Very Dark Gray
142 Trim Combination, Leather Very Dark Gray Camaro and Firebird
143 Trim Combination, Leather Very Dark Gray Firebird
144 Trim Combination, Leather Very Dark Gray Camaro
20Q Molding Color, Blue Metallic
20U Exterior Color, Blue Metallic
28Q Molding Color, Navy Blue Met
28U Primary Color, Exterior Navy Blue Metallic
31Q Molding Color, Bright Green
31U Primary Color, Exterior Bright Green
36Q Molding Color, Fern Green
36U Exterior Color, Fern Green
41Q Molding Color, Black
41T Top Color, Black
41U Primary Color, Exterior Black
52B Trim Combination, Cloth Light Neutral
52D Trim Combination, Cloth Light Neutral
52I Interior Trim, Medium Neutral
522 Trim Combination, Leather Light Neutral
523 Trim Combination, Leather Medium Neutral II
524 Trim Combination, Leather Medium Neutral
56T Top Color, Medium Dark Neutral
63Q Molding Color, Sport Gold
63U Exterior Color, Sport Gold
73B Trim Combination, Cloth Flame Red
73I Interior Trim, Flame Red
79Q Molding Color, Mystic Teal
79U Primary Color, Exterior Mystic Teal
81Q Molding Color, Bright Red
81U Primary Color, Exterior Bright Red
88Q Molding Color, Bright Purple
88U Primary Color, Exterior Bright Purple
92B Trim Combination, Cloth Medium Pewter
92I Interior Trim, Pewter
96Q Molding Color, Cayenne Red
96U Primary Color, Exterior Cayenne Red Metallic
99Q Molding Color, Hugger Orange
99U Exterior Color, Hugger Orange
Old Sep 25, 2003 | 02:09 AM
chuck's Avatar
2000
D82 Paint Special
GU2 Axle Ratio 2.73
GU4 Axle Ratio 3.08
GU5 Axle Ratio 3.23
GU6 Axle Ratio 3.42
T43 Spoiler, Rear
T79 Lamp, Fog Rear
T96 Lamp, Fog
V76 Hook, Tow
Old Sep 25, 2003 | 09:25 AM
NEWBIE T/A's Avatar
Thumbs up Good Info !
So, in that spirit, here's a link !!
http://web.archive.org/web/200112181...regg/gmsi.html
Pick your year & go into general information.
Britt
Javi Fierros
Jul 8, 2015 12:34 PM
mattstrike
Mar 10, 2015 04:46 PM
bernie1951
Dec 10, 2014 10:03 AM
Tang
3rd Gen / L98 Engine Tech
Sep 7, 2002 08:55 PM
