removing AIR...does it thow code or not?
Old Feb 6, 2004 | 06:56 AM
teke184's Avatar
this instruction page says that removing the AIR provisions "Removing this system should NOT throw any codes". ok well that is all fine and good...but i don't like the should part.
who has done this and DOES it thow codes? i'm starting to hear a very noticable whine from my air pump that has started recently, and i've also had some idle issues (not sure if that has anything to do with it or not).
would rather just pull the whole system than spend the money on a new pump.
Old Feb 6, 2004 | 07:43 AM
UnbelievabLS1's Avatar
Yes, it will throw a code, but after removing it, and using block off plates to cover up the holes, it can easily be edited out.
Old Feb 6, 2004 | 07:59 AM
teke184's Avatar
damn
yeah edited out with $250 tune or a $300+ edit program
hm....
should it affect anything other than the SES light? or will the computer start pulling performance?
Old Feb 6, 2004 | 08:46 AM
2001NBMZ28's Avatar
I was thinking about doing this the other day. Went out to the car and pulled the pump fuse and threw a code. Try pulling yours and see what happens. The pump shuts off after the car is warm anyway.
Old Feb 6, 2004 | 10:09 AM
It won't affect performance in any way, but you will have the annoying SES light. The only real benefit to removing the AIR and EGR system is for weight savings and it cleans up the engie bay.
Old Feb 6, 2004 | 10:41 AM
teke184's Avatar
that and the pump is goin i think so it sounds like crap everytime i start the car...
Old Feb 6, 2004 | 07:10 PM
Dark Angel's Avatar
I pulled the pump, hoses and tubes. Just left the solenoid for the vac line, blocked it and would only throw a code every couple months.
Old Feb 6, 2004 | 07:37 PM
tekker's Avatar
omg omg omg! mayb thats the gawd awful noises im getting in the morning when i start my car. just got my new LT headers and every now and then when i start her up it dont sound to hot AIR is coming out!
o and hey teke i think you can just run down to autozone and they will edit it out for like $50.00
gl.
/tek.
kallcium
V6 Tech
Oct 7, 2015 03:39 PM
lt1matt
Mar 21, 2015 07:35 PM
Iamherefornow
Jan 26, 2015 04:57 PM
Jul 4, 2005 05:00 PM
91Bird305
Aug 5, 2002 01:39 PM
