removing AIR...does it thow code or not?
this instruction page says that removing the AIR provisions "Removing this system should NOT throw any codes". ok well that is all fine and good...but i don't like the should part.
who has done this and DOES it thow codes? i'm starting to hear a very noticable whine from my air pump that has started recently, and i've also had some idle issues (not sure if that has anything to do with it or not).
would rather just pull the whole system than spend the money on a new pump.
damnyeah edited out with $250 tune or a $300+ edit program
hm....
should it affect anything other than the SES light? or will the computer start pulling performance?
I was thinking about doing this the other day. Went out to the car and pulled the pump fuse and threw a code. Try pulling yours and see what happens. The pump shuts off after the car is warm anyway.
omg omg omg! mayb thats the gawd awful noises im getting in the morning when i start my car. just got my new LT headers and every now and then when i start her up it dont sound to hot
AIR is coming out!
o and hey teke i think you can just run down to autozone and they will edit it out for like $50.00
gl.
/tek.
AIR is coming out!o and hey teke i think you can just run down to autozone and they will edit it out for like $50.00
gl.
/tek.
Jul 4, 2005 05:00 PM
