Question from over the pond, please help
Another thing which *may* throw a lean code is a very clogged fuel filter- do you know when the fuel filter, under the car, was last replaced? Was it installed in the proper orientation?
I was having similar problems on an S10 Chevrolet truck, the SES light, varying idle speeds- I thought it was a vacuum leak, but when I replaced the past-due fuel filter, everything cleared up- ran a lot better, too.
Thanks everyone for your help.
I cleaned the MAF yesterday and was amazed just how easy it was.
The car ran much better today, if the SES light goes off in the next few days and stays off then I know for sure it's fixed.
Shame I don't have a scanner to reset it and I am not paying the garage again.
P.S. I bet it's quite a trick driving that car around some of UK's narrow roadways.
The only thing I hate is GM bought Daewoo a few years ago and put a Chevy badge on it, now we get cars like the Chevy Matiz with its 796cc engine. What happened to pride and pedigree?
Shame the problem with the warning light has not gone so I have ordered a PCV and Air intake sensor and I may be about to buy a used scanner from a very helpful guy up north who’s into drag racing
All fixed now,
I bought a scanner from a very helpful guy in Manchester (UK), then after more playing about, it turned out to be the short pipe from the PCV to throttle body, there was a split underneath where I could not see.
I sprayed WD40 arround the pipes and the idle speed went up, then I wrapped my fingers arround the pipe and found it, the best thing was that the hole was making a hissing noise and the garage said this noise was a warn Tensioner pulley assy, so thats saved me more £££
Thanks for all the help and advise guys.
dluna333
15
Mar 13, 2015 12:30 PM
jasonduaine
Mar 7, 2015 09:44 AM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
Hurin
Dec 13, 2014 07:38 PM
