Question on MAF sensor????
Old May 29, 2003 | 02:52 PM
AmericanMuscle's Avatar
Which MAF is better Grantilli (cant spell)or SLP's for a LS1 was wondeing why there is a pretty big price difference between the two??
Old May 29, 2003 | 03:03 PM
GoFast908Z's Avatar
Member
The Grantilli is finiky. It can make more hp than the SLP, but it can also cost you hp. A lot of people have had different experiences with that one. The SLP one is more consistant, but less hp. It also won't give you rich/lean fuel problems.
Old May 29, 2003 | 03:56 PM
SSpdDmon's Avatar
I went with the Granatelli MAFS. I got the cold air tuning (richens up the fuel curve) to avoid the rich/lean problems I was experiencing. It's also made out of plastic, so it won't get as hot. So, I say go with Granatelli.
Old May 29, 2003 | 04:15 PM
blacknight's Avatar
The Slp makes mine run very rich. 11.5 A/f when dynoed. However it pulls much harder at higher rpm's. If I were to do it over again I would get a Pace VV. There $184 and haven't heard any problems with them and most have lost 1-2 tenths in et. The GMAF gives everybody problems running lean and there a ripoff.
Old May 30, 2003 | 09:18 AM
mw02's Avatar
stay with a stock maf unless you are somehow pushing 600+ hp.
Old May 30, 2003 | 12:02 PM
SunsetWS6's Avatar
I've been running the Pace 85mm MAF with no problems. On my 01 SS I had the slp MAF but it was junk; set off my SES light.
Old May 30, 2003 | 12:10 PM
mw02's Avatar
I picked up a solid MPH in the 1/4 with a stock maf over the 85mm slp...
Old May 31, 2003 | 01:33 PM
z28200235's Avatar
Is it better to leave a stock Mass Airflow Sensor? I was looking at a 80 mm throttlebody. I would think if you change the throttle body to 80 mm and changed the mass airflow senor would that work? Bec the bigger throttle body would let more air in right?Or is it better to change the throttle body and leave the mass air flow stock..
one more thing what is the differnce between the brands of mass airflow sensors and if you would port your own?
thanks
steve
Old May 31, 2003 | 06:48 PM
blacknight's Avatar
thanks
The difference is there calibrated so your A/F shouldn't get screwed up. When you port and descreen the stock one or by ends a lot of the extra airflow goes right past the maf sensor wires so it isn't picked up by the pcm and then you'll run way lean.
steve
pete53
Dec 9, 2014 07:31 AM
Rich_z28
Sep 13, 2002 03:35 PM
Rich_z28
Sep 8, 2002 12:00 AM
Rich_z28
Aug 29, 2002 11:01 PM
Rich_z28
Aug 29, 2002 10:44 PM
