Question about bolts on Hooker Shorties
I took a set of hooker shorties off of another ls1 and am going to put them on my car.. However, i didnt think to keep any of the bolts? Will the stock bolts from the manifold work to bolt up the headers?
and also, ill need a new seal for both headers where they connect to the Ypipe? Any suggestions on where to get those???
I second using the stock bolts. I had my original exhaust manifolds pulled off, then my original bolts put back on, then when I pulled the heads, I pulled them off again, and put em back on, and they're still holding up well.
You can PROBABLY get away with reusing the gasket, but its so cheap, I say replace it.
ChrisFrez
Jan 18, 2015 08:05 AM
ChrisFrez
Jan 11, 2015 03:47 PM
ferraricameron
Jul 29, 2002 07:46 PM
