Pulling engine
Old Jun 19, 2006 | 03:42 PM
  #16
Sylvrls1's Avatar
Talking Re: Pulling engine
To remove the t56 1. undo the center console in the car undo the rubber boot then take the four allen bolts out of the tail shaft to remove the shifter....2. remove drive line and torque arm.... 3. drain trans plug on the bottom and fill plug on the driver side of the trans case or if you want to just put a plug or rubber glove on the tail shaft to catch the fluid.... 4.remover all plug ins and connectors attached to the trans leave the slave cylinder hooked up. 5. support trans with jack and romove the trans mount bracket from car and mount from trans.... 6.remove the bolts front the bell housing and pull the trans off the bell housing just enoug to get your hand in and unbolt the slave cylinder front the trans... 7. un bolt slave and slide it off the input shaft as you slide trans back.... trans should be out of car and set aside now... 8. tie up slave dont let it hang it will only get in the way.... 9. easly remove bell housing from engine and now you can procede with the engine removal hope this helps if you have any questions i will try to help i have had my t56 out of my car 3 time in a one car garage so i have learned to be good at it........under 2hours in and out
Old Jun 19, 2006 | 04:38 PM
  #17
Mike96z's Avatar
Re: Pulling engine
Done it plenty of times, engine w/ tranny and heads, don't even bother taking the heads off, it'll all come out.
transam_388
Mar 15, 2015 11:53 AM
Chris Anderson
Jan 27, 2015 08:30 AM
cmdeshon
Dec 12, 2014 10:51 PM
Darth Xed
13
Jul 22, 2002 12:45 PM
Doug Harden
11
Jul 14, 2002 04:31 PM
