Which Pulley Is This?(Pic)
Old Oct 18, 2006 | 11:12 PM
  #16
CCCCCYA's Avatar
Re: Which Pulley Is This?(Pic)
You need a new crank pulley/damper, and I would get it as soon as possible. What your seeing in the video is the elastomer ring that sandwitches between the inner and outer rings trying to "squirt" out of the gap at low speeds. At higher speeds centrifugal force is pressing the elastomer to the outer hub and the hub is acting as a keeper. It wont just fly apart due to the way it's made (the inner and outer kind of lock together), but it's not doing your bearings any good. If you replace it and the squeal is still there, then take it to a qualified mechanic and have them check everything out.
Bottom line.. Replace that thing. It's toast..
Good luck.
Dave C.
Old Oct 18, 2006 | 11:29 PM
  #17
lil_mikey69's Avatar
Would you suggest something like this? http://www.ebbsnflows.cz28.com/photo4.html
That is a guide on how to install an ASP U/D Pulley.
Old Oct 18, 2006 | 11:55 PM
  #18
CCCCCYA's Avatar
Yes on the write-up. No on the underdrive pulley. Not really worth it IMHO. But, opinions are like sphincters - everyones got one..
I would just put back a GM part (not a no name knock off). If you just enjoy spending money though Fluidamper makes awfully nice stuff
Dave C.
Old Oct 18, 2006 | 11:59 PM
  #19
Dave C.
I wasn't able to find the GM part online at all, so I just linked to the first type I found readily avaliable. I'd rather go the cheaper route though.
Old Oct 19, 2006 | 09:27 AM
  #20
Sparkz28ss's Avatar
use a GM pully or this .... http://www.fluidampr.com/ ....but its some coin,well worth it
Old Oct 19, 2006 | 11:36 PM
  #21
StudyTime's Avatar
Lots of people seem alarmed by this, but nearly every LS1's pulley does this. If you still have the stock pulley go out and check your car.
Ben T.
Old Oct 20, 2006 | 12:09 AM
  #22
Ben T.
Check my car and do what? I'm not really alarmed...but it is freaking annoying.
HectorM52
Jun 23, 2016 08:42 PM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
