Problems with Eibach Pro Springs
I had the Eibach Pro Springs installed on my 2001 Camaro SS. First two weeks the ride was ok. Now the smallest bump in the road makes the car feel like it is running with no shocks or springs ie, completely botoms out. At highway speed it feels like its floating. Do you think the shocks are gone? If so what shocks should I replace them with to correct this problem? Does Monroe shocks have a heavy duty or high Proformance shock? Has anyone else have this problem with their F-body using Eibach pro springs? My camaro only has 7,000 miles on it. Thanks for any help you can give.
Papajoe 2001SS
Papajoe 2001SS
probably the stock decarbons and although they are not that bad of a shock (contrary to popular beliefe imo) they do leave plenty to be desired. get yourself some bilsteins and youll be gold.
1999 Camaro SS A4 Black/Black/Dark Gray w/ Torch Red Hood Scoop and Torch Red Rear Stripe... 3:23 || SLP Loudmouth || SLP AirBox Lid w/ K&N || SLP Bowtie Grille || SLP CAI || SLP SFC || SLP STB || AZP&S Adjustable Fuel Pressure Regulator w/ 3psi Boost || Sullivan Aluminum Racing Pedals || Yank ST3500 || B&M 24K Tranny Cooler || Jet-Hot Hooker LT Headers w/ ORY || Hypertech 160 T-Stat || SLP Fan Switch || 17 x 9.5 Aluminum Z06 Wheels || Nitto 555R's || Macewen White Faced Gauges w/ Red Dash Bulbs || Xenon Headlights.
i have put the eibach springs on my 99z and they r starting to do the same thing in the back
see when i did the springs the front stack shocks whererusty and i had to replace them but i didn't do the back so right now my back one r pretty soft but i have had no problems with the front
so im going to eventually replace the rear shocks so if you find out about ne good deals let me no or ne info
99' Chevy Camaro Z-28
-K&N F.I.P.I.K.
-Eibach 1.5" drop kit
-SLP LM exhaust
-neon on the floorboards
- Looking for a turbo setup, any tips hit me up bushmaster200021666@yahoo.com
-K&N F.I.P.I.K.
-SLP LM exhaust
<font face="Verdana, Arial" size="2">Originally posted by Papajoe:
... Now the smallest bump in the road makes the car feel like it is running with no shocks or springs ie, completely botoms out.</font>
The only way to really check the shocks is to pull them off the car.
DaveH
Dec 1, 2014 08:08 AM
MIGHTYMOUSE
Aug 29, 2002 09:18 AM
slothgrant
Aug 22, 2002 03:01 PM
