P0507 code and 2000 RPM idle
Old Oct 9, 2007 | 03:18 PM
Z28x's Avatar
I got a SES light and checked the code and it was P0507 which is for high idle. For about a week I've noticed it has been harder to brake (higher idle RPM) and then just the other day I got the SES light. In park the RPMs are at 1400 and when I shift into neutral while on the highway or pulling up to a red light the tech revs and sits at 2000 RPM. I checked the vacuum hoses and they too like they are on fine. What else can I check before I go into the mechanic?
This is for a 4.8L Gen III
Old Oct 9, 2007 | 05:15 PM
Kwiksilverz28's Avatar
Pull the IAC valve and clean it. Use throttle bode cleaner...
Old Oct 10, 2007 | 07:21 AM
Z28x's Avatar
Found the problem!!!! The second throttle cable was stuck and not allowing the throttle to go all the way back down.
Klypto
Mar 23, 2016 09:05 AM
DetroitZ28
Feb 13, 2015 07:33 AM
jayvar
Feb 2, 2015 10:00 PM
91Bird305
Aug 5, 2002 01:39 PM
ferraricameron
Jul 29, 2002 07:46 PM
