oil pressure
Old Mar 2, 2004 | 06:36 PM
Nsty98LS1's Avatar
oil pressure
should i be concerned with my oil pressure. fully warm in gear is about 25-30 psi but never below that. as soon as i'm in the throttle it goe to about 40 and seems to go up according to rpm. but the 25-30 at idle just has me wondering. the 350 i had im my monte carlo idled about the same in gear but that was accptable to me. i don't know much about the ls-1 and was just wondering.
Old Mar 2, 2004 | 07:12 PM
Ex4.6Owner's Avatar
Mine warmed up at idle and in gear is probably around 45-50...It never goes below that.
Old Mar 2, 2004 | 08:17 PM
CrippleFightin's Avatar
I was always led to believe high oil pressure is a good thing...
Old Mar 2, 2004 | 10:04 PM
SpeedzAdisease's Avatar
My idle is around 40 then around 70 in the throttle hard.
Old Mar 2, 2004 | 10:08 PM
AL SS590 M6's Avatar
Moderator
25 psi at idle warm is fine. Even 15 psi at idle warm wouldn't bother me.
What you need to look for in oil pressure is changes from normal for your car.
If it always had 25 then dropped to 20 I'd start looking.
Old Mar 2, 2004 | 10:09 PM
Moderator
High oil pressure "can" mean that something is blocked and not flowing the amount of oil that it should be.
Old Mar 3, 2004 | 09:05 AM
CODY BEHNKE's Avatar
There still shouldn't be such a variance in pressure. All LS1's should be within a certain tolerance of each other. I do think that 20-25psi is on the low side. And 15psi at would have me worried.
Even my Z24 with 165,000 miles runs a steady 20-25psi at idle and 65-80psi when I am driving.
HectorM52
Jul 30, 2017 11:46 AM
Nickster 7
May 1, 2015 09:04 PM
surreybrad
Apr 22, 2015 06:40 AM
KYWes
Apr 15, 2015 05:48 AM
ad356
Apr 11, 2015 08:49 AM
