oil all over the underside of hood
Old Apr 30, 2006 | 05:30 PM
1of365's Avatar
Ok, be easy with me ..... but I have a stock 99SS and noticed a good amount of oil under the hood. The engine is nice and clean but the underside of the hood around the scoop area is wet with oil? Only thing I can think of is when I was getting on the interstate the other day, I down shifted to 2nd from wot in 3rd instead of going to 4th. Any suggestions and do I need to clean off anything else in the engine , thottle body etc?
car is fairly new for me and I'm still getting familiar with the M6.
Old Apr 30, 2006 | 08:43 PM
MasterEvilAce's Avatar
Re: oil all over the underside of hood
if there's a good bit on the hood, oil is probably leaking somewhere and getting on the belts and being flung up at the hood.
that would be my first guess
Old Apr 30, 2006 | 09:03 PM
DaddySS's Avatar
Do you see oil leaking from anywhere?
Old May 1, 2006 | 07:21 AM
AL SS590 M6's Avatar
Moderator
My first guess would be power steering fluid.
Chack all of your fluid levels and see which one is low.
Old May 1, 2006 | 07:34 AM
LS1powerhouse02's Avatar
i would say take a look at your power steering pump. And just a side note. If you were at WOT and accidentally downshifted instead of going up a gear you should definately listen closely to your motor for any ticking. If there is any more ticking than normal then pull the valve covers and take a look at your pushrods. They like to bend when missing a shift like that.
Old May 1, 2006 | 10:38 AM
1of365's Avatar
Thanks for the insight, no ticking noises and no extra oil on anything else? Maybe just a fluke thing. I thought I read somewhere that under heavy pressure the oil can come out the PCV or something?
Anyway thanks agian for the ideas i'll look at those areas to be sure.
SergheiS
Apr 26, 2015 08:15 PM
jasonduaine
Mar 7, 2015 09:44 AM
CARiD
Jan 14, 2015 04:00 AM
siguy
Nov 27, 2014 10:07 AM
