Octane
Old Feb 11, 2003 | 01:00 PM
  #16
rncotton's Avatar
I've run 93 octane since day one. The only exception was when I stopped to gas up in Arkansas and their highest was 91 (which gave me no problems, but it was all highway driving with the cruise set on 78)
I used to own a 2001 Z28 that I bought as a demo. The manager had been driving it for 3 months and ran 87 octane. I had to have the top end cleaner procedure done 3 times to get rid of carbon deposits which the dealership blamed on the other dealership running 87 octane for 3,000 miles.
Needless to say, I won't run the lower octane unless I have to.
FWIW .... Here in Memphis, Amoco sells 93 octane for $1.78 / gallon. Sam's Club sells 93 octane for $1.52 / gallon. I've been running Sam's gas for 4 tanks now with no ill effects.
Old Feb 11, 2003 | 01:41 PM
  #17
OctaneZ28's Avatar
Disciple
I like octane so much it's my frickin screen name! LOL
But seriously, I use nothing but BP/Amoco 93 Octane gas in my Z28. And if there was any Sunoco stations around here, I'd use Sunoco 94 Octane.
Old Feb 11, 2003 | 02:04 PM
  #18
ratio411's Avatar
You can alternate octane ratings depending on the weather and the mods on your car.
The lower octane just causes the car to take timing out of the engine which lowers power output.
If you have mods that lean the car out, definately don't skimp on octane.
If you have mods that cool incoming air and the combustion chamber, you can drop the octane safely and with little/no power loss.
Also, the cooler the outside temp, the less octane you can get away with.
If you drive with a light foot, lower octane is fine too. If you are hard on the throttle, you need cooling mods to drop the octane.
This is what I have learned from experimenting with mods, defeating KR/ping, and experimenting with rich/lean conditions.
Good luck
Dave
Btw: High octane is actually bad for your car if it doesn't require it. It is quick to build up carbon in the cylinder, which causes ping, excessive octane also burns slower and reduces fuel economy when not needed. The best thing to do is vary octane depending on how you will be driving through that tank of fuel and how the weather is while you are on that particular tank. Use only what you need.
Old Feb 11, 2003 | 04:07 PM
  #19
Capn Pete's Avatar
Lightbulb
I like "ratio411" and "robvas"'s ideas better. Anybody running 92+ in relatively stock cars is wasting money IMO. And exactly like "ratio411" said, higher than necessary will cause carbon build up, because the compression isn't high enough in the engine to generate the required heat to completely burn all the fuel, so it leaves deposits, and is actually worse on gas. To me, that isn't worth ~$5 more per tank. Especially not twice a week?!
Old Feb 11, 2003 | 07:17 PM
  #20
stik6shift00's Avatar
i dont think it will hurt it, but i know there are places in the mid west with 93
Old Feb 11, 2003 | 07:42 PM
  #21
98whiteZ28's Avatar
100 octane? that's awsome, but 4.29!! a gallon! eeek thats a tee bit too much for me, hell might as well put some turbo blue in her then
Old Feb 11, 2003 | 10:02 PM
  #22
ttt...have you tried BP yet
Old Feb 12, 2003 | 01:47 AM
  #23
camaro98_speed's Avatar
Yeah 4.29!! its expensive. I put in maybe 3 gallons of 100 to 13.8 gallons of 91. It puts me at like 92.6 octane, if you calculate it out. FIlling up this mix is $6.75 more than all 91. So, for the track, it is worth it. But around town I'm doing ok. When summer comes, its a whole new ball game.
jp
Old Feb 12, 2003 | 08:15 AM
  #24
stik6shift98's Avatar
jp
if you have the money then its a plus
Aug 24, 2015 06:41 AM
dkred94z
Aug 20, 2015 03:09 PM
kahouna23
V6 Tech
Feb 10, 2003 06:08 AM
frankjr8
Feb 8, 2003 11:03 PM
camaro98_speed
Dec 14, 2002 03:50 PM
