No blinker, need help.
Old Dec 21, 2003 | 10:25 AM
Mister Will's Avatar
Question No blinker, need help.
I've got what is probably a simple question. My rear driver's side turn signal isn't working. I don't have time to take it to the dealer before I go on vacation.
Here's a brief discription. It recently stopped working after getting a complete paint job. Then it began to work, I thought my problem was solved. But now its no longer operating again. It may be something as simple as a loose wire or a plug not pushed all the way in.
My actually problem is I can't get to the bulb or the plug to check. I tried getting back there last night but the paneling appears to be secured with press fit fasteners. So I would have to strip them inorder to gain access to the rear driver's turn signal.
Is there something I'm over looking? How do I gain access to the rear driver's side lights?
Thanks in Advance.
Old Dec 21, 2003 | 11:02 AM
PDCamaro318's Avatar
To my knowledge you have to undo the wing nuts on the back panel and take the whole panel off then get to ur taillight but I might be wrong its just what i remember reading on here before. anyone feel free to correct me.
Old Dec 21, 2003 | 12:01 PM
2001NBMZ28's Avatar
Just pull up on the fastners one at a time (start at the back) to loosen the panel, they'll push back in after replacing the bulb. Then pull the carpet back and undo the wingnuts to remove the lamp assembly.
Old Dec 21, 2003 | 02:10 PM
lastZ's Avatar
takes less thann 5 minutes to do what 2001nbmz28 said to do.............real simple
Old Jan 4, 2004 | 08:07 PM
Thanks guys. Was real simple, just like you said. I just didn't want to yank anything out that I could put back in.
Turned out to be a faulty light bulb. Works like it was new now.
Thanks again everyone
Kinglouui
May 26, 2016 11:05 AM
David Dempsey
Mar 12, 2016 12:42 AM
truecontr3
Oct 11, 2015 09:30 AM
surreybrad
Sep 29, 2015 09:00 PM
damnyankee36
Sep 9, 2015 07:06 PM
