New mods... Cam Specs
Old Jan 14, 2004 | 08:40 PM
Michael Ozorowsky's Avatar
Hey everyone. Please help. I've got a 2001 Camaro SS, and I plan to supercharge it with 8# of boost in the near future. I would like to for now get a set of better flowing heads, and a cam that will accomodate my supercharger, while giving me some more horsepower for now. Thanks.
Old Jan 14, 2004 | 10:00 PM
chpmnsws6's Avatar
look for a set of 6.0 heads
Old Jan 14, 2004 | 11:19 PM
What about getting my current heads ported?
Old Jan 15, 2004 | 12:29 AM
Aklaim's Avatar
It's not the flow of the 6.0 heads that is the advantage, its the size of the chamber. Stock LS1 compression is 10.1:1, which is too high for high amounts of boost. 6.0 heads have a bigger combustion chamber which lowers the compression, which allows for higher amounts of boost possible without detonation.
Old Jan 15, 2004 | 12:32 AM
chpmnsws6's Avatar
thank you, i forgot to put that lil bit in there
so if your tune isn't DEAD ON, it will allow you to save ur engine
Old Jan 15, 2004 | 02:58 AM
AL SS590 M6's Avatar
Moderator
And 6.0L heads have the LS6 type exhaust ports.
And as a side note, a stock ls1 with tuning and a good fuel system will handle 8# without any problems at all. I know this for a fact because it's sitting in storage in my back yard with over 30,000 miles on it.
Old Jan 15, 2004 | 10:03 PM
ok, so by lowering the compression before the SC, won't I lose hp? How will that work with 6.0 L Heads, and how much do they usually cost? Do they need to be ported still? Please explain. Thanks.
Old Jan 17, 2004 | 05:19 PM
ttt?
Old Jan 17, 2004 | 07:57 PM
chpmnsws6's Avatar
you will lose a tad bit of HP with the heads but porting is always a nice thing. i think you can pick up stockers for 500 and have em ported for 400. if you got a nice blower cam it will pick ya up a tad N/A and ALOT blown. loose alil now to make a ton later
Old Jan 18, 2004 | 04:14 PM
I'm looking to gain like 30 or 40 to the rear wheels for now. Was hoping I could do that with ported heads and a cam. I can take my current heads off and have them ported without a problem. Thanks.
DirtyDaveW
Mar 15, 2015 07:01 PM
kaoticcamaross
Feb 17, 2015 03:13 PM
pimpss96
Feb 12, 2015 01:28 PM
Brandon Wittmer
Dec 20, 2014 09:51 PM
Queens94z28
Nov 20, 2014 06:03 PM
