new intake
Old Apr 14, 2003 | 01:47 AM
rob jerico's Avatar
new intake
Just finished putting on a holly instake on my 98 camaro, car starts up but won't idle! I can rev it up and it runs fine but it dies at idle?
Old Apr 14, 2003 | 02:06 AM
dj haf's Avatar
did you do it yourself, or did you have someone else do it for you (professionaly)?
Old Apr 14, 2003 | 08:31 AM
stik6shift98's Avatar
did u reset the pcm?
Old Apr 14, 2003 | 10:31 AM
rob jerico's Avatar
PCM?
No I did not reset anthing, I had the battery unhooked for the install, I hooked the battery back up and it fires up but wont idle.
Old Apr 14, 2003 | 11:11 AM
JasonD's Avatar
Admin Emeritus
Arrow
http://web.camaross.com/forums/showt...threadid=94398
Simple process, I hope this takes care of your problem! Sounds like it would!
Old Apr 14, 2003 | 11:48 AM
ssvegas's Avatar
when i replaced the stock air lid with an SLP lid, i noticed that when i bliped the gas it would almost dip down to 400-500rpm.
so i drove it around the block and WOTed it a couple times.
it still would drop to 400-500rpms.
after, i went home shut off the car then started it back up after a couple a mins.
this is all i did and the thing worked itself out.
it idles normally at 800ish and when i blip the gas its fine.
this might not b the same, but i thought id share.
LETZRIDE
Outside of United States
Jul 9, 2015 07:17 AM
MadMav
Jun 15, 2015 09:51 PM
jwade88
Jun 14, 2015 09:38 PM
Countryboychevy
Jun 13, 2015 02:49 PM
maybe2fast
Mar 26, 2015 08:34 AM
